Page 4 of 32 FirstFirst 1234567891011121314 ... LastLast
Results 31 to 40 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #31
    Jun 2002
    Malaysia
    so what do you download? Windows XP Embedded SP2 Update Evaluation Edition?
    Will it work on WinXP SP1?
    I'm downloading the SP1 Tools, SQL Server Desktop Engine, WinXP SP1 Embedded Database
    Do I need the WinXP Embedded SP2 too?
  2. #32
    FLAC SFiorito's Avatar
    May 2004
    yes, you need XPe SP2. It'll run on Win2000 or any version of XP.
  3. #33
    Jun 2002
    Malaysia
    Stuck in the installation process of the XPe SP2.
    I think I installed SP1 correctly, run setup from Disk1, and then installed the following in order:
    -Tools Setup
    -Database Engine Setup
    -Database Setup
    -Remote Boot Setup
    and then exit
    Went to disk3 and run the setup.exe program and installed the following
    -Database Engine Update
    -Tools Update
    but when I clicked Database Update, out comes a window that its extracting files to a temp directory on the WinXP drive, and after that, it asks me to backup my database before I update it. I click OK to resume the installation.
    Then the Service Pack Installer comes up and tries to connect to the name of this PC. After a while out comes the following message.
    Service Pack Installer - Error
    Cannot Connect to the database - please check the database
    Setup cannot continue
    I even tried to run Start->All Programs->Microsoft Windows Embedded Studio->Component Database Manager and then it says Connecting to server MyPCNAME... and then times out saying "Cannot connect to the database at MyPCNAME. Please verify your database connection."
    I am stuck at this part, what does it mean verify your database connection? Where do I set it?
  4. #34
    May 2004
    Do you have windows firewall running? If so you'll have to make some ports open to allow file sharing and sql server to receive connections. Also, make sure SQL Server is actually running.
  5. #35
    Jul 2004
    I'm following the directions linked in the first post in this thread...
    When I get to the stage where I run "ewfmgr c:", I still should not have connected my CF card, right?
    OK, so when I get to the stage where I run "ewfmgr c:", a window pops up very quickly then dissapears. So I can't tell how much RAM my overlay is taking up. BUT, I don't get an error saying that an EWF volume cannot be found either.
    As a test, I deleted a couple of directories (my pictures, my videos) and then rebooted. Upon rebooting, those directories are gone. Correct me if I'm wrong, but shouldn't they have been there since EWF should have been enabled?
    Did I go wrong somewhere along the way?
  6. #36
    May 2004
    you need to open up a command line and run ewfmgr in the command line, not from the run menu otherwise you won't be able to see it.
  7. #37
    Jul 2004
    OK, I opened a command prompt and now I get this message when I run "ewfmgr c:"
    "failed getting protected volume configuration with error 1."
    Any idea what is wrong?
  8. #38
    Jun 2002
    Malaysia
    Quote Originally Posted by SFiorito
    That's the problem. I didnt know how to get the SQL server running in the first place.
    Anyhow, I noticed that I need a reboot at that point. After that the SQL server will start to run and I no longer have installation issues.
    Btw, SFiorito, great write up. Really straight forward! Well done.
    Just a couple of points
    1) Maybe add the reboot part above into your guide
    2) You need to mention that when creating resmany.dat, its not a "simple text file". It really needs to be empty! I had pulled some hair out trying to figure out when HORM didnt work, till I created an EMPTY file..
    A couple of questions
    Can we delete all the directories made by XPE after we have extracted minlogon, ewf.sys, ewfmgr and ewfntldr? How do we do it, uninstall or just a straight delete?
  9. #39
    Jun 2002
    Malaysia
    Jackboot,
    try the suggestions made on this thread:
    http://www.winxptalk.com/ftopic14936-0-asc-0.html
  10. #40
    May 2004
    well, you shouldn't have to reboot to start up sql server. it should've been installed and started automatically. If not you can just use the services admin tool (or run "net start mssqlserver"). Regarding the resmany.dat file, all you have to do is create a text file using the right-click new menu and rename it.
    jackboot: have you rechecked all the registry entries? did you remember to change the permissions on the root key before you imported the reg entries? what type of drive are you installing on? is it a regular ide drive?
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
