Page 8 of 32 FirstFirst 123456789101112131415161718 ... LastLast
Results 71 to 80 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #71
    Dec 2004
    Quote Originally Posted by masch
    SFiorito,
    Unfortunately removable media is very unlikely. Where am I going to mount a second hard drive?
    I use HORM basically just to boot up to the same state all the time. In fact, I dont mind if its not ewf protected but it has to be- that's the source of all my problems.
    I wrote simple programs to monitor the states on my car, the mileage, the consumption, all these data and I want to store it on my second partition (drive D). I have the software I wrote in drive C. THe program resides on drive C but has its databse on drive D. But everytime I try to load the software, it loads blank, as if there are no data in the database file on drive D. That drives me crazy.
    Btw, what do you mean Front Ends has to have HORM support? How will the program have HORM support if anything it writes to its internal database will be wiped everytime the user turns off the PC? If there's a way, I 'd like to know too.
    Have a look at this thread on HORM support in Road Runner.
    HORM and RoadRunner...
  2. #72
    FLAC SFiorito's Avatar
    May 2004
    *BUMP* for new guys...
  3. #73
    Jan 2005
    Atlanta, GA
    Just wondering if an administrator could make this thread sticky? I have to dig for this thread every time...
  4. #74
    Jan 2005
    Atlanta, GA
    masch, is kind of an old thread, so don't know if you're still having the same problem, but instead of mounting a 2nd drive, how about just splitting the drive into 2 partitions? (ewf on drive c:, and drive d: open for writes). Works for me...
  5. #75
    Jun 2002
    Malaysia
    bosskong
    are you sure its working? do you use it in a HORM environment?
  6. #76
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by SFiorito
    I had to find this down the list.... Admins... Please sticky this!
    I followed your instructions to the letter, but for the life of me... the damn file protection would insist on restoring winlogon.exe. I tried everything, but I did manage to get it working. I can't remember the sequence, but I have minlogon installed and it has improved my startup times. My next project is to get HORM working. I am not going to bother with XPe... seems like to much work for too little benefit. I'll eventually do the nlite thing and run from CF, but for now... if I can get HORM working from the hard drive, that will do nicely. Thanks for paving the way!
    By the way... save a couple of profile configuration items, every piece of hardware worked flawlessly! WIFI worked immediately without any reconfigurtion for WEP. Bluetooth settings were retained... etc. I am going to canabalize my installation again and start from scratch. I want to research the fastest possible memory device (CF or whatever) to max boot times. The only thing that could possibly be cooler would be to EPROM the whole shootin match.
  7. #77
    Mar 2005
    what's your boot time after the tweak?
  8. #78
    Mar 2005
    Quote Originally Posted by wei2cool
    I'm still far from satisfied, but I went from 35 to 26 seconds... I have to play with bootvis to improve things, and I have had some issues with the system since installation, but... that's the noted improvement.
  9. #79
    May 2004
    what hardware are you running? specifically mobo+CPU, ram, and hard drive?
  10. #80
    Mar 2005
    Asrock K7S41GX, Athlon 2000XP running @12.5x, 512mbDDR, Creative Audigy 2, 80gb WD (7200rpm 8mb cache).
    I Underclock the processor to keep it running cool. Did a bench on this and it costs me about 1 second.
    I am running Hauppauge WinTV Go-TVFM, 3com USB Wifi, TrendNet BT-101 Bluetooth, Deluo BU-303 GPS. I am an SE... so I have the OS/Hardware stuff in hand, but your thoughts are certainly welcome. I've optimized the bios as much as I can from the settings available. I had a very fast startup before i started adding crap (sub 15sec), but I have not done any real optimization of the system since installing the system in my car. I am pretty sure the creative drivers are costing me some time. I was mostly concerned about functionality before I took my recent holiday with my car. I didn't notice how slow it was until I actually had to use it for its intended purpose.
    I really have to play with the system using bootvis to see what's going on, but I am sure I can get the sequence running more efficiently. I noticed that the system hibernates pretty darn fast (about 3 seconds), but the startup from hibernation, is brutally slow (25 seconds), so I'm betting I have a disk channel performance issue, just not sure where. Basically, I gotta start rippin and playin to find out whats up.
    I'm pretty sure I am going to gas the mainboard and processor in favour of an Intel product, and I'm gonna try the CF mod you speak of... but if you have any other thoughts, I'm all EYES
    I'd love to know what performance you are seeing with your configuration... CF versus HDD and so on.
    Thanks for the interest!
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
