Page 9 of 32 FirstFirst 12345678910111213141516171819 ... LastLast
Results 81 to 90 of 320
Thread: New EWF + MinLogon and CF instructions
  1. #81
    FLAC SFiorito's Avatar
    May 2004
    well, like you say bootvis is your best bet right now so you can better understand what's causing the slowdown. if it takes that long to come out of hibernation then it could very well be something with your HDD since it has to read about 512MB from your drive. if you have minlogon installed, run bootvis with winlogon instead since there are some incompatibilities with minlogon. as far as CF, it's pretty fast if you get the higher end cards and slim down your install enough so that it fits. but running the system in read-only mode can cause some people headaches.
  2. #82
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    Quote Originally Posted by SFiorito
    Read only mode?.. If I do decide to use CF, I would want it to be R/W... is this not possible??? or do I need to do some more reading . I would assume that since it is CF, it would by default be R/W. If the only reason for using R/O is speed, I'd be inclined to sacrifice the small amount it might cost.
    Yeah... I'm pretty sure it's HDD related. I have to check to see what config I have set in windows for DMA and such.
  3. #83
    Mar 2005
    Well.... I wish I had done some recent benchmarking before doing this, but.... I decided to go out to my car and play with bootvis. Holy Crap! I just let it optimize my system and what a huge performance difference! I am still in the same boat as before with return from hibernation (expected), but raw boot times have increased noticably! I have better than expected results. Now I have to get a stop watch on the situation. I will have to ghost the drive for backup and then really start playing, but I feel that right now, I can boot as fast as return from hibernate... of course, I'm just guessing with out actually timing this. I'll be posting my results.
    In short... if you haven't tried bootvis... you need to!
  4. #84
    May 2004
    flash storage needs to be used in read-only mode otherwise the constant writing to the disk will end up killing it fairly quickly. flash only has a limited number of write cycles.
  5. #85
    Mar 2005
    Bump for those lookin
  6. #86
    Jun 2002
    Malaysia
    Does anybody know how to disable the scandisk at startup? In the original article it mentioned something about deleting a .dat file. I searched the system and there was no such file, but it still does error checking everytime I boot
  7. #87
    I have downloaded XP Embedded SP2, but get a prompt to enter the key. However, I didn't get one with the download. How do I get and eval key?
  8. #88
    Raw Wave
    Jun 2004
    On the beach
    @masch - do a search in the registry for autocheck - delete the value within the autocheck key.
  9. #89
    Any one know if this will work on win2k or if there is any way to do the same thing in win2k?
  10. #90
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    hi sorry this might have been asked before, but i'm really tired.
    anyway, is it cool to use HORM without a CF? i got xp sp2 and just want to do the horm thing.
    how would i go about setting the hibernation point?
    THANKS!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
