Page 1 of 32 1234567891011 ... LastLast
Results 1 to 10 of 320
Thread: New EWF + MinLogon and CF instructions
    FLAC SFiorito's Avatar
    May 2004
    Okay, I tried to make it as simple as possible in the time I had. I'm pretty sure I covered everything in this doc.
    http://granturing.blogspot.com/
    **EDIT** New Link
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Is this link working for somebody?
    Dec 2004
    it works put you have to be a member of msnuser
    May 2004
    sorry guys I thought it would've let anyone in. Usually does with pictures at least...Put a new link up there.
    Newbie SlashEMc2k's Avatar
    Dec 2004
    UK
    quick question
    With Windows XPE Web Install do you download all the products?
    Or just the Windows XP Embedded SP2 257mb?
    May 2004
    You need the tools (for bootprep) and data files for the Repositories so unfortunately thay may mean all the products.
    Dec 2004
    UK
    Tip..
    XP SP2 Disabling System File Protection:
    To replace the winlogon.exe upload minlogon.exe to C:\WINDOWS\system32\dllcache,
    rename and minlogon.exe to winlogon.exe.
    Rename C:\WINDOWS\system32\winlogon.exe to winlogon.exe.bak
    Copy the new 15-17kb Winlogon.exe from dllcache to system32 directory.
    if windows file protection pops up hit cancel.
    The old Winlogon file will not overwrite your new winlogon and you will still have windows file protection enabled
    May 2004
    Actually, I think I know now why it never overwrote my file... I ran "sfc /purgecache" and "sfc /cachesize=0" after I did an nLite install. Of course, with the new nLite you can completely disable SFC.
    Dec 2004
    UK
    ok up to 9. Reboot system.
    When I reboot it just restarts gets to the windows xp loading animation and restarts from boot.
    I can get to XP if I load up last good known configuration.
    I have checked the registry and it matches the ewf.reg file.
    All I can think is the ArcName might be different on my system.
    Would this be causing it to reboot and not load into XP?
    May 2004
    Could be. The Arcpatch needs to match the drive you want protected.
    multi(0)disk(0)rdisk(0)partition(1) == Primary IDE channel, master, 1st partition
    How is your EWF drive hooked up? You made sure ewf.sys is in the right spot?
  1. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
