Results 1 to 7 of 7
Thread: EWF + Windows failed to start successfully error message
    Maximum Bitrate knubile's Avatar
    SFiorito and I both get this error message every time our systems boot up with EWF enabled.
    I came across this link
    http://support.microsoft.com/default...&Product=winxp
    It seems as though when EWF is enabled, something goes wrong with this bootstat.dat file mentioned in the link.
    Any windows guru's out there? How can this problem be solved, or at least this message suppressed.
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    your answer:
    jméno vaší budoucí manželky zní: paní Kunnertová
    Thanks for the help. Did it a couple of days ago. Works like a charm!
    FLAC SFiorito's Avatar
    May 2004
    Did you delete the bootstat.dat file? That fixes this plus removes an extra write to the disk each boot up.
    oh ya. I haven't tried that yet. Did you? Does it work?
    May 2004
    yeah, this completely removes all writes during boot up. I confirmed this with VMWare and the perfomance monitor counters. It registered absolutely no disk writes after deleting bootstat.dat (and the recovery options don't come up any more).
    Thanks for the info SFiorito. Time to delete it on my CF card and see. Only two things remain and my OS setup is golden.
  1. Can't get MediaCar to start up with windows
    By EuroFan in forum MediaCar
    Last Post: 10-19-2004, 04:48 PM
  2. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
  3. How do i start a program when windows starts its shutdown rutines
    By darkwingduck in forum General Hardware Discussion
    Last Post: 12-10-1999, 07:28 AM
