Page 2 of 9 FirstFirst 123456789 LastLast
Results 11 to 20 of 81
Thread: minlogon and now ACPI does not shutdown
  1. #11
    Maximum Bitrate knubile's Avatar
    Something new. If I enable hibernation and tell it to hibernate when I press my power button(power options), it will hibernate.
    So it is getting the ACPI signal. It's not a driver issue. Hibernate works, but for some reasone shutdown does not.
    Anyone? This is my last problem and my OS will be complete.
  2. #12
    Variable Bitrate egeekial's Avatar
    May 2004
    I don't know, but I wonder if this is related to my problem: mine freezes when I try to shut down.
  3. #13
    Doesn't seem related. Mine doesn't even try to shut down. No freezing or anything. It's as if I never pressed the button.
    I read your thread. Yours sounds a little more serious.
  4. #14
    OK. I'm definitely using the proper minlogon file now and it still doesn't work.
    I'm getting ****ed!!
  5. #15
    FLAC SFiorito's Avatar
    May 2004
    Is your BIOS set to shutdown after holding the button down for X seconds or just clicking it once? Try holding the button down until it starts shutting down.
  6. #16
    Rub One Out Motoko's Avatar
    Hertfordshire, England, Earth, Solar System
    hmmm mine shuts down. Though it didnt shut down the first time i installed Xp (nLite with minilogon) strange.
    CarPC status: iPod, 3,456,217 songs so **** you
  7. #17
    Bios is set to shut down immediately. But from what I understand that doesn't get respected by Windows. If I hold it down for 4 seconds, it just cuts out. There was no proper shutdown.
  8. #18
    Dec 2004
    hmm that's weird. I just did a clean nlite install and replaced winlogon. My system shuts down fine.
    Wayne
  9. #19
    Guess that's what I'll have to do as well. I was hoping my 11th OS install attemp would be my last for while. Guess not.
  10. #20
    Ok. Fresh nlited XP install. I just swapped winlogon files and added the one Config entry. Shutdown doesn't work. It worked before the swap to minlogon.
    I guess there must be something I'm removing in nlite.
    Can somebody with a working minlogon acpi system please post their nlite settings file so I can compare?
