Page 3 of 9 FirstFirst 123456789 LastLast
Results 21 to 30 of 81
Thread: minlogon and now ACPI does not shutdown
  1. #21
    Maximum Bitrate knubile's Avatar
    Holy *****. I create an xp install CD using nlite. I didn't remove any components at all. All I did was add the unattended install part.
    Same thing! I add minlogon and ACPI shutdown doesn't work!!! This is a full XP install.
    Those of you that have minlogon and ACPI working, do you use an unattended install?
    All I'm doing is replacing the winlogon file and add one registry item
    [HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
    "Config"=dword:00000017
    What's going on?!?!
  2. #22
    Raw Wave
    Jun 2004
    On the beach
    It doesn't work using unattend ... I spent three hours today trying to get it to ACPI etc and it still don't work! I'll keep plugging away - really bugging me as I'm a Systems Engineer by trade and do this sort of thing as my job and I can't even get this right! Grrrrrr
  3. #23
    Dec 2004
    ive just been faffing about with XPe, after 4 days it finally all got here.. anyways, when i added the minlogon component, it wanted me to choose from a range of acpi shizzle for acpi to work.... mybe theres more than 1, or you need to include another file....
  4. #24
    Raw Wave
    Jun 2004
    On the beach
    Gonna give it a go without nLiting to see if it is a problem with how I am doing the minlogon registry changes, once I've done that I'll retry with an nLited XP Installation
  5. #25
    Great. Please keep me posted with progress. I'm going to be too busy for the next few days, so I can't keep experimenting. It would be great to know what the issue is. I'll be able to go to bed without thinking about registry entries.
  6. #26
    Constant Bitrate shiltz's Avatar
    Dec 2004
    Massachusetts
    i'm having the same problem now, was working fine with minilogon, then I ended up having to repair the install as it screwed up installing SP1, once I switched back to minilogon after installing SP1 it won't shutdown hitting the power button.
  7. #27
    hmm. i've been using an SP2 install CD from the get go.
    What service pack level is being used by those of you who have minlogon working?
  8. #28
    Dec 2004
    I am using an nlited xp sp2 and shutdown works fine for me
    Wayne
  9. #29
    I assume you are using minlogon bigman? Can you post your nlite settings file?
    Also, did you following SFiorito's latest minlogon instruction(where you just add the config line?) or did you delete the whole winlogon key first?
    Dec 2004
    I followed the old way and I am using minlogon
    Code:
    [Main]
    Env = 0.99.6 beta.1.1.4322.2032.Microsoft Windows NT 5.1.2600.0..en-US
    Target = Windows XP Professional SP2 - build 2180
    [Pages]
    Remove Components
    Unattended Setup
    Integrate Drivers
    Integrate Hotfixes
    Options and Tweaks
    Create a Bootable ISO
    [Components]
    ;# Applications #
    Accessibility Options
    Briefcase
    Calculator
    Charmap
    Internet Games
    NT Backup
    Screensavers
    Wordpad
    ;# Drivers #
    Battery
    Bluetooth Support
    Display Adapters
    Display Adapters (old)
    IBM Thinkpad
    InfraRed
    ISDN
    Modems
    MultiFunctional
    Multi-port serial adapters
    Portable Audio
    Printers
    Scanners
    SCSI/RAID
    Smartcards
    Sound Controllers
    Toshiba DVD decoder card
    Wireless Ethernet (WLAN)
    ;# Internet Utilities #
    Client for Netware Networks
    Communication tools
    FrontPage Extensions
    Internet Connection Wizard
    Internet Explorer
    Internet Information Services (IIS)
    Java Virtual Machine
    MSN Explorer
    Netmeeting
    Network Monitor Driver and Tools
    NWLink IPX/SPX/NetBIOS Protocol
    Outlook Express
    Peer-to-Peer
    Server Printing Support
    Synchronization Manager
    Tcp/Ip Version 6
    Vector Graphics Rendering (VML)
    Web Folders
    Windows Messenger
    ;# Multimedia #
    Images and Backgrounds
    Luna Theme
    Media Center
    MIDI audio support
    Mouse Cursors
    Movie Maker
    Music Samples
    Old CDPlayer and Sound Recorder
    Paint
    Speech Support
    Tablet PC
    Windows Media Player
    Windows Media Player 6.4
    Windows Sounds
    ;# Operating System Options #
    Administrator VB scripts
    Desktop Cleanup Wizard
    Disk Cleanup
    DR Watson
    File and Settings Wizard
    Framework
    Help
    Manual Install and Upgrade
    MS Agent
    Out of Box Experience (OOBE)
    Search Assistant
    Security Center
    Shell Media Handler
    Task Scheduler
    Tour
    Web View
    Zip Folders
    ;# Services #
    Alerter
    Application Layer Gateway
    Autoupdate
    ClipBook
    CTF Loader
    Distributed Link Tracking Client
    Error Reporting
    Fax Services
    Imapi
    Indexing Service
    IPSEC Policy Agent
    Messenger
    Network DDE
    Performance Logs and Alerts
    QoS RSVP
    Quality of Service (Qos)
    Remote Registry
    Removable Storage
    Secondary Logon
    Service Advertising Protocol
    SNMP
    System Event Notification (SENS)
    System Monitor
    System Restore
    TCP/IP NetBIOS Helper
    Telnet Server
    Terminal Services
    Uninterruptible Power Supply
    Universal Plug and Play
    Volume Shadow Copy
    WebClient
    Windows Firewall/Internet Connection Sharing (ICS)
    Windows Time
    Wireless Zero Configuration
    ;# Language Support #
    Arabic
    Baltic
    Central Europe
    Chinese Simplified
    Chinese Traditional
    Cyrillic
    Georgian
    Greek
    Hebrew
    Indian
    Japanese
    Korean
    Thai
    Turkish
    Vietnamese
    Multilanguage Support (LANG dir)
    Service Pack Messages
    Input Method Editor
    ;# Directories #
    [KeepFiles]
    msconfig.exe
    scrnsave.scr
    mshta.exe
    [RemoveFiles]
    blastcln.exe
    clock.avi
    dvdupgrd.exe
    dvdplay.exe
    winmine.exe
    winmine.chm
    winmine.hlp
    [Options]
    ProfilesDir = "%SystemDrive%\HOME"
    ;#ISO maker#
    isovol =
    isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
    [Drivers]
    C:\NLDRV\NETRTLX.INF,0
