Page 7 of 9 FirstFirst 123456789 LastLast
Results 61 to 70 of 81
Thread: minlogon and now ACPI does not shutdown
  1. #61
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    the minlogon_shutodown.exe fixed it for me.. you just have to run it at startup
  2. #62
    was Boston -> now Canada!
    Quote Originally Posted by starfox
    It looks like you might need to install the power saving modules from XPe into XP to get it working....
    Anyhow, i couldn't be bothered looking too deeply into this problem (i'm sure MS will fix it someday when one of their MSDN premium subscribers bugs them about it), so i wrote a workaround which might be sufficient for most people here (it is for me!).
    Attached is a small app that'll run silently and leave an icon in your system tray. It looks out for WM_POWERBROADCAST messages and calls SetProcessShutdownParameters() to become the highest priority app to receive shutdown messages. If PBT_APMQUERYSUSPEND or PBT_APMQUERYSTANDBY are received (system is entering sleep / standby mode and the OS queries applications to see if it's okay to enter this state), the app sends back BROADCAST_QUERY_DENY to abort entering sleep / standby mode. A timer is then started, which calls ExitWindowsEx(EWX_POWEROFF, EWX_FORCEIFHUNG) to shutdown the PC.
    So if you set your PC to 'standby' when your power button is pushed, this app will cancel the standby command, and shut down your PC instead.
    Starfox I ran across your small app searching why minlogon caused my PC not to shutoff. I got it workin well now. I wanted to send my thanks along to you.
    Chuck
  3. #63
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    No worries, glad it's useful to you.
  4. #64
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    I'm using it too. I thought for sure my ACPI problems were due to me removing something I shouldn't have from XP, but a full install results in the same problem. With this app I don't have to hibernate every time, or manually select shut down in Road Runner. Thanks.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  5. #65
    Jun 2002
    Malaysia
    Starfox, you rock!
    I've been reinstalling/uninstalling XP and XPe to find out what's wrong with my setup. I didnt know it was because of minlogon till this thread.
    Your workaround works flawlessly. Thank you!
    Between this and frodobaggins' CDA workaround, I think a lot of my headaches with eWF is starting to disappear
  6. #66
    Variable Bitrate NeoMatrixJR's Avatar
    Aug 2004
    Arround Des Moines, IA
    S3 Suspend not working with minilogon
    Cool for everyone who can shutdown... but I'm trying to suspend to ram! Any Ideas?
  7. #67
    Aug 2004
    Pearland
    if you are suspending to ram.. then you would have no need to use minlogon....
    minlogon speeds up the boot time considerably for those of use who are doing a cold boot every time we get in the car
  8. #68
    Aug 2004
    well, I heard minilogon also reduces the footprint. I've also got space consideratoins...does anyone know the difference b/t winlogon and minilogon for this? Also, to switch back to winlogon, what registry change do I need to make?
  9. #69
    Aug 2004
    Pearland
    minlogon does not decrease the footprint.. XPe does...
  10. #70
    Aug 2004
    well, I figured it out in a moment of sheer...well...something... I must have had old minilogon/ewf files. I upgraded the ewf files from a zip file someone posted, but not minilogon. I just upgraded that and now it works fine!
