Results 11 to 20 of 22
Thread: Minlogon - wireless issue
  1. #11
    Low Bitrate GARB-E's Avatar
    Oct 2004
    Thanks for the help, after alot of messin about its finally working.
    Just incase anyone else is struggling I set up a new admin user with password on the host computer and it all worked fine.
    momanz, when you restart your machine do you have to put in a password for the first time? if not, do you know how to get around it? I have searched around to no avail.
    Cheers
  2. #12
    Jul 2004
    Yeah, everytime I reboot windows remembers the user name but I have to enter the password for the share. I seem to recall that on other systems there is a check box in the logon window that asks if you want to save the password. This checkbox is absent on my logon window. It may be an aritfact of using minlogon or I may have a needed service disabled. I haven't really looked into yet. If you use hibernation to power down windows will remember that you are logged on. I'll post a reply if I come across a solution.
  3. #13
    Low Bitrate Pepe's Avatar
    Jul 2003
    Kingston, Ontario, Canada
    Quote Originally Posted by GARB-E
    Cheers
    To save yourself the trouble of having to type out the username and password everytime you reboot, you could always create a batchfile to create a drive mapping for you. Use the "net use" command as follows:
    NET USE X: \\computername\sharename /USER:computername\username password
    And if you were to create a drive mapping with Windows Map drive feature, and specify to "reconnect at logon" and "connect using a different user name", it will remember your mapping for you with every reboot.
    99 Ford Ranger - Bagged and laying frame
    Current Carputer project:
    Done:
    Custom mounted 7" LCD w/ TSK in radio bezel
    Custom center console for relocated headunit
    Via Epia M10000
    GPS
    MP3
    OPUS PSU
    DVD
  4. #14
    Oct 2004
    For some reason the command does not work correctly using minlogon.
    It works for the first time but when the computer is rebooted and then the command is run again you are posed with a question saying that the connection has been remembered and do you wish to overwite it. If you say yes the connection gets denied and is totally lost. If you decline the connection remains but you still have to input the password!
    The same thing happens with windows logon using another user with respect to putting in the password.
    Any ideas?
  5. #15
    Jul 2004
    I've also tried the net use command before with the same result. The password is not stored.
  6. #16
    Raw Wave tj!2k4's Avatar
    Oct 2004
    Any ideas?
    Add " /persistent:no" to the end of the net use command. So, the whole string shoudl read...
    NET USE X: \\computername\sharename /USER:computername\username password /persistent:no
  7. #17
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    Hey i have the same problem. just did the minlogon thing and now no network access. I click a pc on my workgroup and it says I don't have permission. I don't have a password on my host pc....
    EDIT: I just redid my network wizard on both pcs and now i cant even see my host computer grrrrr looks like no minlogon for me if it doesn't let you access another computer via wifi/lan
    Any ideas?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  8. #18
    Jul 2003
    So. Cal.
    same problem here with minlogon. Is it possible to use winlogon to then switch users if need be? I'm not sure how this would be done, but i might just go back to winlogon to save myself some trouble with file transfers.
  9. #19
    Raw Wave
    Jun 2004
    On the beach
    Wifi access is working fine here with Minlogon, authentication and everything, double check that your Network Location Service is started and the DNS Client Service.
  10. #20
    FLAC migel628's Avatar
    Mar 2004
    New Windsor, NY
    ...After doing the hack i cannot connect to the home pc via the car pc, but I can access the car pc via the home pc...
    I'm hitting the same wall right now w/ minlogon on my nlited XP install, but on a wired connection. I can connect from my home PC to the car PC, but not the other way around. Everytime I try to go from car PC to home PC, I get a permission error. It's just weird, b/c car PC to home PC worked before the minlogon switch...Any ideas?
    "I'm a dick!"
    "I must seek knowledge and it's bastard son truth" - The State
  1. Replies: 268
    Last Post: 05-28-2012, 10:49 AM
  2. Instructions on getting FREE wireless internet from T-Mobile using GPRS
    By bankingdom in forum Wireless Communications
    Last Post: 08-16-2011, 03:37 PM
  3. Wireless router to wireless router wirelessly
    By Jackso in forum Wireless Communications
    Last Post: 02-22-2010, 12:30 PM
  4. wireless card or wireless car and access point?
    By vanroth in forum Wireless Communications
    Last Post: 06-08-2004, 11:46 AM
  5. Wireless lilliput 7 touchscreen wireless.?
    By Nokia6600 in forum LCD/Display
    Last Post: 02-29-2004, 08:45 AM
