Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: XPe,nLite??
  1. #11
    Maximum Bitrate knubile's Avatar
    I can't make out anything readyon does that SFiorito and I haven't accomplished using components from XP embedded.
    With what we figured, anytime you hibernate it creates a new image(no flushing). Anytime you shutdown normally it will start up again from the last saved image. That simple.
    Is there anything else readyon allows you to do lars46?
  2. #12
    May 2003
    I noticed that you have your OS and apps on Sandisk Extreme 1G CF Card. Where do you have your MP3's and GPS software??? Are they on a standard hard drive??? If so, aren't you defeating your purpose of having the CF Card??? To answer your question, they are about the same but for me ReadyOn is better for me because I do not know anything about programming and at 50 and being dyslectic I have no wish to
  3. #13
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    I thought the big issue with ReadyOn was single unit licensing. When last I spoke with James @ VCI they hadn't decided how they would handle it. Apparently they hadn't anticipated it being sold that way and thus didn't build in appropriate mechanisms to protect it from illegal distribution.
    In any case, from what I read in the ReadyOn thread and the EWF thread, the two solutions appear to have identical functionality. It's hard to get a definititive idea of actual boot speeds since few posters bother to specify their full configuration (hardware and software), test conditions, and measurement methodologies. Lack of standard process for doing this almost certainly accounts for the wide variation in reported boot times ~(3 - 60s).
  4. #14
    FLAC SFiorito's Avatar
    May 2004
    There's no programming involved in using EWF. From what I've read of ReadyOn, EWF is probably less if not just as complicated as ReadyOn....and it's free... The reason I'm using the CF card is so I can fit the whole system into the smallest enclosure as possible and with a CF card the temperature of the system will be very low. My media files will be on an external drive. Right now it'll be a usb laptop drive, but in the future I want to keep everything in a portable harddrive player (like a creative zen) so I don't have to continuously shuffle songs and videos all over the place. Keeping data files on an external drive doesn't defeat the purpose because we can remove the external drive when we're not using the car, so in the heat and cold the CF card will be fine and the harddrive will be safe indoors.
  5. #15
    Updated my sig lars46.
  6. #16
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    Quote Originally Posted by stric
    Why not to use XPe? Wouldn't that reduce boot time?
    Could some of you who have XPe and nLite post your boot times?
    And yes, there is still the licence issue.
