Results 1 to 10 of 16
Thread: XPe,nLite??
    Slovenia (EU)
    XPe,nLite??
    Why not to use XPe? Wouldn't that reduce boot time?
    Could some of you who have XPe and nLite post your boot times?
    Variable Bitrate egeekial's Avatar
    May 2004
    XP Embedded has to be customly built. It is a big pain in the ***, and this is why we are taking components of it and putting them into our nLited XP Pro installs.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Also, XPe was built off of Pro components... since the machines in our cars and trucks are similiar to home computers in that they play media and run multiple applications at the same time with networking support.... It's much easier to use an OS built to do this... than to build an OS from scratch to do this...
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    May 2003
    I am using Xp Pro and from when I apply power till I get to the desktop is 15 seconds. Only 5 seconds is disk drive usage. The secret to the fast boot is SATA and ReadyOn.
    May 2004
    Quote Originally Posted by lars46
    ReadyOn?
    May 2003
    In short, ReadyOn makes an image similar to suspend to hard drive and write protects your drive. You turn the power on and when you are done, kill the power ( do not shut down the computer.)
    The link for ReadyOn is www.vci.com
    More info here: Anyone looked into ReadyOn for XP boot?
    FLAC SFiorito's Avatar
    May 2004
    You should give EWF and HORM (hibernate once, resume many) a try. Check this forum for instructions. It's what ReadyOn provides, but I'd be interested to see if it's faster or not than ReadyOn on your hardware. I read the ReadyOn thread a while ago and the results seemed mixed. Most of the people looking to use XPe components on XP Pro are doing so for cost, simplicity, reliability, and most importantly to install on a CF card (for temperature, shock, or size reasons).
    May 2003
    I am not using a SATA drive in my truck pc. I use a notebook drive that is good for about 250 g's when running and am still getting 25 seconds from when power is applied to the desktop. OS size is not a concern for me when my GPS programs and my MP3's take up 35 gigs
    May 2004
    Yeah, I remember that thread, but I thought it was concluded to be VaporWare. Do you have it?
    May 2003
    Yes I do and I like it. If you want to make changes to the system, just flush the image, make the changes and reboot. Then you make a new image and your good to go. James Redmond (jredmond@VCI.com) is the Rep I dealt with. There are a few learning curves like disabling ReadyOn for your removable drives because If you don't, the blue screen of death. Seems to work with all on my hardware. The only hardware change was to move the USB GPS off the hub and put it directly to the PC.
