Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: XP Embedded Components
    Constant Bitrate goosey2099's Avatar
    Dec 2004
    Staten Island, NY
    Hello everyone. I must say that i love this forum and it has helped me get really far in my quest for a carputer, yet i still need to get a stable windows xpe installed. I have allready gotten a copy of XPe to run on my target computer, but i have noticed that i need to add a lot of custom componets. Can someone please post either you .SLX file, or list all the components that you have in your project.
    Thank You All
    -and don't tell me to cause thats all i've been doing for 5 months.
    FLAC SFiorito's Avatar
    May 2004
    Well, most of the topics in this OS forum are about optimizing XP, especially on using XPe components in XP. Specifically EWF and minlogon. You should read through some of these threads and you'll see that with nlite we can create an "embedded" image much easier than you can with XPe and the performance/size is relatively the same.
    Dec 2004
    Staten Island, NY
    I have read through them, but maybe someone should list all the MANDATORY components so you can run and configure the operating system from inside the Xpe. I mean I got the os to load but Iím missing my Motorola wifi card drivers and I donít to have directx8 I want directx9c.
    May 2004
    I don't think we're on the same page... I'm not using XPe at all. I pulled two components from XPe (EWF and minlogon) and got them working on a regular XP installation. That way you don't have to worry about using the XPe Tools to build an image or the licensing issues, you just install XP like you normally would or use an nLite modified installation of XP and you install either or both of EWF and minlogon. It's much easier than dealing with XPe and the end product is basically the same.
    Dec 2004
    Staten Island, NY
    Well the licensing issue i have no problem with (i allready took care of that) but i would still like some feedback from people who have XPe and what kind of components they include into their custom image. Thanx
    Low Bitrate linuxguy's Avatar
    Dec 2004
    Alabama
    Do this...install a hard drive on your target pc with all of the dev software already installed run TAP then save that file and put the drive back in your dev pc then run Target designer using the data you got from TAP from there you check your build, configure it how you want it, build it and copy to a cf card (or whatever media your using) then put that on your Target device and boot into FBA
    I had a perfect quote to go here,
    but hell only knows what I did with it....
    Dec 2004
    Staten Island, NY
    Maybe i'm not clear enough. I allready have xpe running, and i have no problem with that. But there are a lot of components that are sometimes required to run Centrafuse, OBD2, WiFI Cards, GPS applications... and other software. I want to know what people put in there images( items like System Properties, Internet Explorer, DAO Engine, etc...)
    May 2004
    No you weren't clear at all... I don't know if there are any people actually using XPe in their systems. I know a lot of people experimented with it, myself included, but I think most got discouraged just for the problems you're experiencing. Basically, your best bet is to look at the requirements for your frontend and work from there. You may want to contact your frontend developer and see what 3rd-party tools and Windows services (as in MDAC, Media Player, or IE) he uses. Dealing with 3rd-party drivers and software may be more complicated so you'll just have to use trial and error...
    Or you could just use an nLite XP + EWF + MinLogon install and be done by now.... (sorry I just had to throw that in there)
    Dec 2004
    Staten Island, NY
    I have tried nlite, but its not nearly the same as XPe
    Dec 2004
    Alabama
    OH! in that case use regmon and filemon to see the registry entries and files your programs use to work..then you have to create a custom component using all of those dependencies and files... search on MSDN for creating custom components.
  1. XP Embedded Packages
    By loserbaby22 in forum Software & Software Development
    Last Post: 11-18-2004, 03:58 AM
  2. Lilliput and xp embedded
    By mikevsgeek in forum LCD/Display
    Last Post: 08-17-2004, 02:11 PM
  3. PowerMate on Windows XP Embedded
    By JasonSurratt in forum Input Devices
    Last Post: 01-14-2004, 12:06 PM
  4. Using ME With XP Embedded
    By Dr Frag in forum ME Archive
    Last Post: 11-19-2003, 02:16 AM
  5. Via and XP Embedded
    By orangewhip in forum General Hardware Discussion
    Last Post: 05-26-2003, 05:48 PM
