Results 21 to 30 of 31
Thread: Remove Taskbar
  1. #21
    Low Bitrate farolfo's Avatar
    Quote Originally Posted by trod
    I have the same problem with the task bar.
    Could I have the VB source code for hidetaskbar / unhidetaskbar or otherwise have a runtime version with the notification removed?
    Thank you.
    As another alternative, which replacement shell should I use?
    Where can I find it?
    try freezeshell, it's a command line app. freezeshell with no arguments hide task bar and desktop icons. If you use switch off (freezeshell off) your desktop will be restore. If you need source code you can find in "plastico ht" project on surceforge
    Attached Files Attached Files
  2. #22
    Nov 2005
    Wink
    Thats perfect. Thanks a lot.
  3. #23
    Jul 2005
    NJ
    Quote Originally Posted by farolfo
    hey man i just downloaded the hidetask bar from you..but the only thing is..i dont know how to turn it off now??? hah..can you just tell me how to turn it back on now so i can see everything...
    thanks
    Jason
  4. #24
    Jul 2005
    NJ
    hey ok i just reset the computer and its back now...but i also opened that prog a few times before i restarted..so basically i just click on it again and it comes back?
  5. #25
    Newbie edubidu's Avatar
    Jan 2006
    Question May I get the source code?
    Quote Originally Posted by kollitiri
    I made two different programs
    you can run them separetelly. Down Right you will see the status of the taskbar, for 3 seconds.
    I hope this will help you
    Michael
    Hi! I found your .exe via and It works super fine! Thanks!! My question: May I get the source code of your 2 examples? - I install public computers @ University of Fribourg Switzerland and don't want the studies to interact during installation process. So I looked for a program that hides the task bar during installation process and shows it @ the end. So I found your example. No I'd like to modify the "taskbar on" and "...off" showing delay on the bottom right. @ the same time, I'm interested to learn VB. That's why I ask you for the code...
    If possible to get it, thank you very much . If not, what a pity , but I accept.
    Birgit
  6. #26
    Feb 2007
    Cleveland, Ohio
    there is an easier way to do this. simply kill the explorer service on boot. the taskbar will not appear and if u try to access it, it will not launch.
    u can also make this a polling service using the system id so if a user or application tries to launch the explorer window, it will kill the process.
    i am using my touchscreen systems in a quasi "kiosk" mode. only certain apps run on startup (place ur apps in the all users startup folder), the user id is a fixed autologon admin (hack registry in winlogon). by disabling the explorer service, u minimize OS tampering.
    i am still working on refining my code for the polling service (allowing taskmgr to launch for remote access)
    lang068
    "Always the janitor... Never the Project Lead!"
  7. #27
    Nov 2007
    @kollitiri
    Can i spread this hide/unhide taskbar app? I gathered some reg tweaks in one reg file and i would like to add this program in that zip with those reg tweaks for win32 but i must ask you first
    p.s. I added in readme.txt that i found program here but is that enough? Would you like to mention your name or...?
  8. #28
    Maximum Bitrate bes51659's Avatar
    Sep 2005
    Vasastaden, Stockholms Län, Sweden, Sweden
    I just unticked the box "keep the taskbar on top of ...". Not good enough?
    I am sure the shell thing is the way to go, but maybe this is simpler, safer and as good?
  9. #29
    Variable Bitrate bambam's Avatar
    Dec 2004
    Upstate New York
    Quote Originally Posted by GARB-E View Post
    I have now removed all visable traces of windows except for the taskbar.
    Does anyone know how to totally remove it? Ive checked this forum and other groups but cannot find a way of totally removing it!!!
    Haven't tried any of these yet but take a look here:
    Remove Taskbar
    Another approach
    Registry Hack
    "Imagination is more important than knowledge." -AE
  10. #30
    Aug 2010
    Thumbs up
    Quote Originally Posted by kollitiri View Post
    Michael
    You rock michael!! this was exactly what i needed
  1. Replies: 0
    Last Post: 12-05-2004, 08:00 PM
  2. why does my taskbar show when i run gps???
    By TheKurbster in forum FrodoPlayer
    Last Post: 11-10-2004, 08:36 AM
  3. Remove XM and Minimode buttons ?
    By RobIles in forum FrodoPlayer
    Last Post: 07-15-2004, 05:28 PM
