I have now removed all visable traces of windows except for the taskbar.
Does anyone know how to totally remove it? Ive checked this forum and other groups but cannot find a way of totally removing it!!!
Printable View
You can use a shell replacement so you no longer use explorer and modifiy it to the way you want. I pretty sure you can make it not show the taskbar.
You probably already know this but you can set the "auto-hide" feature on and the taskbar will disappear until you bump the edge of the screen where the taskbar is located.
Totally out of my league!!!!!! Was hoping of some sort of setting change in the registry. The only problem with auto hide is that on boot it displays the taskbar for a few seconds.Quote:
Originally Posted by Quattro-A4
if its for a touchscreen setup, I would say like bugbite and suggest to set the autohide feature (right click on the start menu, select properties, go to taskbar, select autohide, click OK).
should do the trick.
If you want to completely hide Explorer, why not just use your frontend as the shell?
Hi Garb-e
i just made it
it is very easy to use, toggles taskbar on and off, as you may want
It is written in VB. You can have the code
Cheers
Michael
Garb-e
new version with check control to leave it as it is (hide or unhide) and exit button.
Michael
:nw: Thanks for the program and for the offer of having the code but if im honest with you I have no knowledge in programming at all.Quote:
Originally Posted by kollitiri
Would it be possible to alter the programme, so that it will switch the taskbar off when it is run, without having the user to manually switch it off.
Thanks once again for your time in producing the programme, I have spent hours trying to find something like this. :nw:
What would you like to do?
Please explain it to me and I will try to do it!
Do you want to different programs, one for on and one for off??
Michael
