Page 1 of 4 1234 LastLast
Results 1 to 10 of 31
Thread: Remove Taskbar
    Low Bitrate GARB-E's Avatar
    Oct 2004
    Remove Taskbar
    I have now removed all visable traces of windows except for the taskbar.
    Does anyone know how to totally remove it? Ive checked this forum and other groups but cannot find a way of totally removing it!!!
    I see dead kittens Quattro's Avatar
    Dec 2003
    New York
    You can use a shell replacement so you no longer use explorer and modifiy it to the way you want. I pretty sure you can make it not show the taskbar.
    Installed
    Asus A7N8X-VM - AMD Mobile Athlon 2400
    512 Ram - 60GB HD - Opus 150w
    Lilliput 7" - Rikaline 6010
    [00000000000001100010-] 98% Completed
    Check Out My Install!!!
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    You probably already know this but you can set the "auto-hide" feature on and the taskbar will disappear until you bump the edge of the screen where the taskbar is located.
    Want to:
    Oct 2004
    Quote Originally Posted by Quattro-A4
    Totally out of my league!!!!!! Was hoping of some sort of setting change in the registry. The only problem with auto hide is that on boot it displays the taskbar for a few seconds.
    Maximum Bitrate Marsupial's Avatar
    Feb 2004
    Montreal
    if its for a touchscreen setup, I would say like bugbite and suggest to set the autohide feature (right click on the start menu, select properties, go to taskbar, select autohide, click OK).
    should do the trick.
    -Mars
    FLAC SFiorito's Avatar
    May 2004
    If you want to completely hide Explorer, why not just use your frontend as the shell?
    Registered User kollitiri's Avatar
    Oct 2004
    Athens, GREECE
    Hi Garb-e
    i just made it
    it is very easy to use, toggles taskbar on and off, as you may want
    It is written in VB. You can have the code
    Cheers
    Michael
    Attached Files Attached Files
    Oct 2004
    Athens, GREECE
    Garb-e
    new version with check control to leave it as it is (hide or unhide) and exit button.
    Michael
    Oct 2004
    Quote Originally Posted by kollitiri
    Hi Garb-e
    i just made it
    Cheers
    Michael
    Thanks for the program and for the offer of having the code but if im honest with you I have no knowledge in programming at all.
    Would it be possible to alter the programme, so that it will switch the taskbar off when it is run, without having the user to manually switch it off.
    Thanks once again for your time in producing the programme, I have spent hours trying to find something like this.
    Oct 2004
    Athens, GREECE
    What would you like to do?
    Please explain it to me and I will try to do it!
    Do you want to different programs, one for on and one for off??
    Michael
  1. Replies: 0
    Last Post: 12-05-2004, 08:00 PM
  2. why does my taskbar show when i run gps???
    By TheKurbster in forum FrodoPlayer
    Last Post: 11-10-2004, 08:36 AM
  3. Remove XM and Minimode buttons ?
    By RobIles in forum FrodoPlayer
    Last Post: 07-15-2004, 05:28 PM
