Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
Thread: bootprep.exe
  1. #11
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    UltraII and logcsupply (tried 2 cards, same model, on both the plugin style adapter as well as the adapter that has a IDE plug).... Already updated bios to latest available beta, absolutely no effect
    Roy
    2005 Range Rover 4.4
  2. #12
    FLAC SFiorito's Avatar
    May 2004
    what cable you using? 40 conductor cable or new ATA style 80 conductor cable? i think this might be the same problem I was having when I first started all this. you have to use the older style cables. also, you're formatting the drive as FAT32?
  3. #13
    São Paulo, Brazil
    Hey SFiorito,
    I really hope your patience isnt running out on me.... I'm really sorry for all these problems mate...
    I will check what cable it is (they are normal IDE cables AFAIK)... however one of the CF-IDE adapters I'm using (the one i'm using for most of the tests) is a direct plugin into the Mobo...
    I initially formatted and created the partition with MS-DOS 6.22 bootdisk using FAT (not FAT32) on another computer, but when I try to boot or access (fdisk or even "c:" or whatever letter I try) I cant access, or when I try to run FDISK i get "Unable to read physical drive" (something to this effect - im far from the machin ATM_
    Roy
  4. #14
    May 2004
    no, my patience isn't running out...
    your BIOS harddrive settings are all set to AUTO right? i'm trying to think of what else it could be...
  5. #15
    cheap custom title JC-S60's Avatar
    Mar 2004
    Ghent - Belgium
    Quote Originally Posted by RoyN
    Hey SFiorito,
    Try to set your C/H/S manually, identical to how the other booting pc detects them, sometimes it helps...
  6. #16
    São Paulo, Brazil
    I'm going to try the C/H/S settings copying them from the other machine... I had tried tweaking some stuff like turning Large Blocks on and off, 32bit access on and off, but nothing seems to make much difference...
    Another thing I noticed... If I use a newer FDISK (the one that asks you when you start it if you want to allow large blocks or not) I see the drive, create the partition, but when I reboot no partition has been created, and if I go into this FDISK again it shows the drive, but shows it as "no partitions"....
    Roy
