Results 1 to 8 of 8
Thread: Formatted cluster size and wasted space on CF cards?
    Jul 2004
    Just wondering how much disk space is being wasted when you use FAT vs NTFS on your compact flash cards. It occurred to me while formatting a drive today that the FAT cluster size is 16k vs 1K for NTFS on a 1gig drive. Is this significant or are we talking about under a megabyte? Seems like it could be a bit more....
    Another question I have along similar lines is how much RAM is typically consumed for disk writes when EWF is used on the averagish system. Anyone have any experience with this yet?
    -momanz
    Jan 2003
    Ruston, LA
    Depends on the size of your files,
    Lots of small files under 16k will lead to a lot of waste.
    or files, slightly over, etc
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    Jan 2003
    Ruston, LA
    of course, unless your really tight, don't worry about it
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLAC SFiorito's Avatar
    May 2004
    Unless you're installing software with EWF enabled or deliberately making changes to the filesystem you won't use up very much RAM. I've usually seen it at less than 1MB during normal operation.
    Jul 2004
    I have an ancient 256meg CF card that I was thinking of experimenting with. It benchmarks between 2x-5x speed though... I may just break down and pick up a 512meg sandisk ultraII, costco was selling these for $48 although... I just saw the extremeIII 20mb/sec.... wow, price is a bit high though $219... decisions decisions...<grin>
    Opps forgot to mention this is the 2gig version being sold at bananapc.com.
    May 2004
    I got my 1Gig ExtremeIII for $109 at B&H: http://www.bhphotovideo.com/bnh/cont...=356015&is=REG
    Keep in mind that there's no tool for making the disk "fixed" like there is for the UltraII and ExtremeI.
    Constant Bitrate CustomZ02's Avatar
    Austin, TX
    Starting new project. After some jackass broke in and stole my screen.
    Jul 2004
    Ok, since my last post I've had to do a couple of more installs and this is what I've found. For an Nlite CD epia drivers integrated I have a 150 meg ISO image, that when installed gives me a windows folder that is
    Fat32
    size 386MB
    Size on disk 398MB
    wasted space 12MB
    NTFS 4kb cluster size (default)
    size 388 MB
    size on disk 393MB
    wasted space 5MB
    NTFS 512b cluster size
    size 388 MB
    size on disk 388MB
    wasted space 457kb
    So what does this mean... Well it's like frodo said, unless you really need to squeeze an extra 5-10 mb out of your CF card, don't worry about it...
