Page 1 of 3 123 LastLast
Results 1 to 10 of 26
Thread: minlogon -> "acpi power button can't shutdown" workaround
    Maximum Bitrate starfox's Avatar
    May 2002
    Australia
    Introduction
    Minlogon.exe is an XPe component which can be used on standard Windows XP installs to speed up boot time. Information about this is available on this thread:
    Using minLogon to speed up booting and decrease footprint
    This small application may be a workaround for a problem that a few people are experiencing in this thread: minlogon and now ACPI does not shutdown
    Problem description:
    After replacing winlogon.exe with minlogon, the computer's ACPI power button will not shutdown the computer if it's behaviour is set to do so in Control Panels, Power Options.
    Please note that you may not need this workaround! Many people do not have this problem. There's no need to use this workaround if your PC can shut down when you push the ACPI power button.
    This app provides a workaround:
    This application intercepts a sleep / standby message, aborts it, then tells the computer to do a poweroff / shutdown. More detailled information about what it does is included in the readme file packaged in the zip.
    Installation instructions:
    Unzip the zip file somewhere, then put a shortcut to "minlogin shutdown.exe" in your startup group (or in the appropriate registry entry if you like). Then in control panels, power options, set the computer to standby when you push the power button. Start the application. The next time you push the ACPI power button, the computer will shut down as it should.
    Attached Files Attached Files
    Variable Bitrate CARLOS_CET's Avatar
    Aug 2004
    NH
    Great app!!! Saved my life!!! When I turn on my system, minlogon shutdown starts up and a window comes up on my desktop. Is there a way to get rid of that window and just have it start up by being minimized in the system tray?
    May 2002
    Australia
    The application will start minimised in the system tray unless something's not right on startup. Usually this is because haven't set the behaviour for your ACPI Power Button to Stand By in Control Panels / Power Options.
    Aug 2004
    NH
    Thanks. I'll give that a try.
    Mar 2006
    LEEDS UK
    what if.... like me there isnt an option for stand by? just hibernate, shutdown or ask me.
    so my computer still aint shutting itself down
    that box just keeps on popping up at startup
    May 2002
    Australia
    What motherboard are you using? Most modern boards support standby.. might need to turn on S1 or S3 power saving modes in your bios.
    Jan 2006
    Italy
    great...
    how can i run it like service? or starting with rr?
    i don't use explorer like shell but rr...
    for me the program shutdown the system but not hide the message, even if i set correctly the acpi button
    Low Bitrate jadz's Avatar
    Nice! Just what the doctor ordered for my TinyXP Install.
    DIGItonium
    Guest
    I was wondering if you guys ever tried the "shutown" command? I like that program as well with MinLogon, but I wonder if you guys want to try this out:
    Go to Run and type "shutdown -s -t 00"
    -s = shutdown
    -t = set timer (00s in this case)
    I think the shutdown program uses the same command... interesting anyhow.
    May 2002
    Australia
    Yup yup, that shutdown command should work too, but this app's just a workaround so you can still press your ACPI power button and have your system shut down like it used to before switching to minlogon.exe.
    Fyi, my app doesn't call shutdown.exe, it makes Win32 API calls to grant itself shutdown access then calls ExitWindowsEx().
    I should really post the source code here someday, just have to find where i kept it.
  1. linking into laptop power button
    By corsamel in forum General Hardware Discussion
    Last Post: 04-23-2010, 05:53 AM
  2. Rewiring ATX power button
    By DCC in forum Power Supplies
    Last Post: 02-07-2008, 06:17 AM
  3. Relocating computer power button
    By King_Xerxes in forum General Hardware Discussion
    Last Post: 02-21-2007, 10:15 PM
  4. PC power button problem
    By BMp3W in forum Power Supplies
    Last Post: 10-12-2002, 03:36 AM
  5. getting an odd motherboard to power on
    By karmann in forum Power Supplies
    Last Post: 11-28-2001, 06:27 PM
