Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Making a CF card bootable
  1. #11
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Update
    tried cloning the drive, and swapping the hard disk and CF card, then rebooting..... won't reboot ! I just can't get the CF card bootable ! There must be a way.....
    kpjuk
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #12
    FLAC SFiorito's Avatar
    May 2004
    What CF-IDE adapter are you using. What type of IDE cable are you using? It may need to be the older style 40 conductor (ATA33) cables, not the new ATA66 or ATA100 cables. That's what got me the first time too. Your best bet is to install XP on a hard drive and then just copy over the files to your NTFS formatted CF drive (or FAT, but you need to run bootprep on it).
  3. #13
    Dec 2003
    West Midlands
    Da, Daaahh,
    (emulated windows start up sound !)
    It's working ! The only thing I changed was to put the CF/IDE adaptor at the end of the IDE lead instead of in the middle. I then ran fdisk /mbr, rebooted, ran fdisk to reset the partition, rebooted, tried to sys it, with no luck. Thought I would give bootprep a try just in case, and blow me the bugger fired up !
    Lots of problems still, in an effort to save space my nLite config puts the docs/settings onto drive D:, but in this config drive D: is the DVD drive (Doh!), so one step forward and you know the rest.....
    Thanks guys for your perserverance. Still not sure why the CF won't boot to DOS, but hey who cares.
    Now for a new nLite config, and some test time on CF v 4200 Hard drive.
    Thanks for the help and support.
    KPJUK
  4. #14
    May 2004
    If your drive is NTFS formatted you don't need bootprep. Bootprep is only needed for FAT partitions, so I'm guessing your CF disk is FAT, right? It's better that way when using EWF anyhow. I wouldn't get my hopes up WRT the speed of your CF card. Unless it's a SanDisk UltraII, Extreme, or ExtremeIII it won't be very fast. Those 3 cards are the fastest out there. I've tested all 3 and they work great, but if you just bought some cheapo 512MB card it probably won't be very fast. I've gotten XP down to 200MB so far and have never needed to move any directories. Just make sure you disable paging and hibernation (if you don't plan on using it). I've noticed with the latest nLite that even when I select "Disable paging file" that XP still creates a pagefile.sys on my root so I need to disable paging again manually, reboot, and then delete the file myself.
  5. #15
    Dec 2003
    West Midlands
    Thanks SFiorito,
    I am guessing that this current 512MB card is going to "upgrade" my digital camera, but I really wanted to get this working to see which direction my installation overall should go in. I probably should have read up a bit more before I bought the card, but it was only for playing with anyway. As I bought a 512MB memory card, for my M10K I should have gone for the 1GB CF disk, but didn't realise the size of the Hiberfil.sys is directly proportional to your memory count (DOH!) hindsight as they say......
    Anyway, I want to do a comparison of CF boot performance against the old 4200 disk I have at the moment. I haven't invested in my final disk yet, and if the improvement is only slight, I may hold out for a 7200 disk when they drop to sensible pricing instead of going for the 1GB mem card, I don't have temperature issues here in the UK, so I am looking at the CF for performance not Temp / crash proofing ! Decisions decisions.....
    to nLite v8 and beyond .........
    I will post my findings later.
  6. #16
    Newbie SlashEMc2k's Avatar
    Dec 2004
    UK
    SFiorito can you post your nlite setup and any info on files u removed to get it down to 200mb..
    I`m having difficulty to get in under 300mb..
    Thnx
  7. #17
    Constant Bitrate NOS TANG's Avatar
    Mar 2004
    OH USA
    Quote Originally Posted by SFiorito
    Not sure if it will help when using nLite cause I've never tried it, but in my case I had to disable the pagefile and then reboot a couple times prior to ghosting the laptop drive . The first time I copied an image over to the CF drive it gave that "no pagefile" error on every boot up. I checked the settings and it said disabled, but then on every reboot it came back.
    Also I can now enable or disable the pagefile on the CF microdrive and it works fine, no more errors. Not sure why, but it works.
  1. XP Pro on CF card working!!
    By knubile in forum WinNT Based
    Last Post: 01-03-2005, 07:48 PM
  2. CF card procedures?
    Last Post: 12-15-2004, 01:54 PM
  3. Hibernate file on CF card?
    By TrickerZ in forum General Hardware Discussion
    Last Post: 11-20-2004, 05:09 PM
  4. Autorun CF card on insert???
    By Ill1 in forum General MP3Car Discussion
    Last Post: 07-09-2004, 10:19 AM
  5. Those running Linux from CF, how to make bootable?
    By eugenen in forum Software & Software Development
    Last Post: 11-10-2003, 01:18 AM
