Results 11 to 20 of 29
Thread: MINLOGON without ewf, easy install with files
  1. #11
    The land of polar bears and nekkid blonds
    Wrong thread or what ? Reply five days later ?
    I hope it wasn't me you where after.... sure it wasn't minlogon _only_
    but come on, how difficult could it be to download the package, unzip, replace winlogon.exe, import reg-file... done.
    /M
  2. #12
    Dec 2004
    Quote Originally Posted by Maximus
    /M
    why read through a 20 page thread to figure out the quirks of their 'elegant' solution when you could check out a KISS solution developed by someone else?
    just the path of least resistatance
  3. #13
    FLAC SFiorito's Avatar
    May 2004
    there's no quirks man, just some people having problems with WFP. i updated my first post in the original minlogon thread a while ago to reflect the changes (i.e., only one registry value to import).
  4. #14
    Quote Originally Posted by linden_arden
    Sure, but I replied to "mattress" post that just came out of the blue and seemed irrelative to this whole thread, so I was just asking if it was my answer to where you could find minlogon that was wrong.
    No 20 pages either... like I said.. Post #4, but now that syfenx's link is online again people can choose anyone they like.
    /M
  5. #15
    Newbie dirtwarrior's Avatar
    Mar 2005
    minlogon
    I am expermenting with minlogon with good sucess so far thanks to you guys. I would like to take it a little further and incorporate minlogon and other XPE stuff into an install CD where it is all up and running right after install is finished. I am trying to make a blazing fast windows xp and quick on startup too. I know some about doing this but would need detailed info to acomplish this. I know others would find this info to be of great use. Can anyone help?
  6. #16
    May 2004
    all you need to do in order to include minlogon into an nLite install is just modify the hive files in the i386 directory of your CD and add entries for the files that need to be copied over (making sure those files are in the i386 directory when you burn the CD).
    You want to use this info:
    Code:
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF","NextInstance",0x00010003,1
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000",,0x00000012
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","Service",0x00000002,"EWF"
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","Legacy",0x00010003,1
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","ConfigFlags",0x00010003,32
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","Class",0x00000002,"LegacyDriver"
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","ClassGUID",0x00000002,"{8ECC055D-047F-11D1-A537-0000F8753ED1}"
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","DeviceDesc",0x00000002,"EWF"
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000","Capabilities",0x00010003,0
    HKLM,"SYSTEM\CurrentControlSet\Enum\Root\LEGACY_EWF\0000\Control","ActiveService",0x00000002,"EWF"
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf","ErrorControl",0x00010003,1
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf","Group",0x00000002,"System Bus Extender"
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf","Start",0x00010003,0
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf","Type",0x00010003,1
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0","Enabled",0x00010003,0
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0","Type",0x00010003,1
    HKLM,"SYSTEM\CurrentControlSet\Services\ewf\Parameters\Protected\Volume0","ArcName",0x00000002,"multi(0)disk(0)rdisk(0)partition(1)"
    HKLM,"SYSTEM\CurrentControlSet\Control\Class\{71A27CDD-812A-11D0-BEC7-08002BE2092F}","UpperFilters",0x00010000,"EWF"
    ewf.sys      = 100,,,,,,,4,0,0
    ewfmgr.exe   = 100,,,,,,,2,0,0
    HKLM,"SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon","Config",0x00010001,23
    minlogon.exe = 1,,,,,,,2,0,0
    all the ewf stuff goes into hivesys while the minlogon stuff goes into hivesft file. the file entries are added to the txtsetup.sif file. ewf is configured as disabled so you can boot up your system and make any changes before enabling it. i think it's better to let the system boot up at least once normally before enabling minlogon and ewf. copy the ewf.sys, ewfmgr.exe, ewfntldr, and minlogon.exe files to your I386 directory renaming them as such:
    ewf.sy_
    ewfmgr.ex_
    minlogon.ex_
    ewfntldr---->delete the current ntldr and replace it with ewfntldr
    that should be good enough i think. it's pretty much what i use for my nLite CD's.
  7. #17
    Mar 2005
    Where would I get the files ewf.sy/ewfmgr.ex/ewfntldr I have minlogon already. At one time I just replaced winlogon with a renamed minlogon in the i386 folder and got a blue screen and installation halted at that point. I will try this. The html stuff wher does this go?
  8. #18
    Mar 2005
    Hklm not html
  9. #19
    Apr 2005
    Cape Coral, Florida
    Thanks for the files man. It saves me the time of having to go and Download XPe and install and the rest of the crap.
    A1-MTX
    VIA EPIA M1000
    Ultra Low Profile 512MB
    Hitachi Travelstar 30GB 2.5"
    Toshiba 8x Slim Type DVD
    Casetronics C134
    Lilliput 7" Touchscreen
    ElmScan OBDII
    Travellar Mini Keyboard
    Holux GM-210
    Hauppauge WinTV/FM USB
  10. #20
    Newbie syfenx's Avatar
    Jan 2005
    a place in TX
    bump
    bump
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. 2002 Montero Limited Install...
    By Squid in forum Show off your project
    Last Post: 10-06-2009, 04:41 PM
  3. Replies: 264
    Last Post: 04-05-2009, 08:09 AM
  4. Using EWF on regular WinXP
    Last Post: 03-17-2009, 07:43 PM
  5. How should i install this?
    By jnusaira in forum General MP3Car Discussion
    Last Post: 08-13-2004, 04:03 PM
