Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Need help optimizing Win2k for fast boot
  1. #11
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    I think most of the timings are taken using Bootvis, to give at least a standard view on boot time. I don't think Bootvis starts its clock until after the BIOS has done its bits, so in your case for comparison you would have to take off that time.
    There is a trial version of XPLite that allows you to remove some of the windows components after your install, so you would be ok using that on what you have now. Just a word of warning, you need to make sure you have your image backed up before you start this, as in my experimentation, I have blown away a dozen images or so, by trying different options.
    Good Luck Mate
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
  2. #12
    Dec 2003
    West Midlands
    Hi, another thought, rather than have the OPUS kick in when the IGN/ACC is turned, can it not be initiated from the central locking circuit (assumes you have Central locking). Getting in the car and turning the key can take 5 seconds, giving the appearance of shaving time off your boot !
    regards
    KPJUK
  3. #13
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    Quote Originally Posted by kpjuk
    regards
    KPJUK
    Thanks for the advice in the previous message. Regarding this advice (quoted above), I built a circuit to run off the door open signal. Since it isn't every time that we unlock the door with the remote (like mornings pulling out of the garage), I tied into the door opening circuit to start boot up from that instant. That did help... a little. By the time the car is started, pulled out of the garage and the seat belt is buckled, it's only a few more seconds (4-5) before we have sound. So basically, tying into the door cut out the delay time the Opus was adding to the boot up plus a little more. Sound comes even faster if we run MP3s from hibernate, but I really prefer XM.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 02:39 PM
  2. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 10:57 PM
  3. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 04:21 PM
  4. Using DOS and 98 at once, can I toggle at boot time with a keypress?
    By bombboyer in forum Software & Software Development
    Last Post: 04-08-2003, 12:13 AM
  5. Enabling/Disabling Setup via boot disk?
    By gizmos in forum Software & Software Development
    Last Post: 07-14-2000, 11:39 PM
