Results 1 to 10 of 13
Thread: Need help optimizing Win2k for fast boot
    Maximum Bitrate R32 JUhl's Avatar
    Nov 2004
    North Atlanta
    I would rate my computer skills as sufficient to get me out of a jam, but not sufficient to program. I know how to edit and save my Bios, but I don't know what everything does in there. I only feel comfortable editing the registry when I have clear instructions to follow.
    So that gives you an idea of where I'm coming from when asking for help in decreasing the boot-up time of my Win2k carputer. I'm planning the install for this weekend despite having a 90 second boot time. I've hunted for a tutorial and glanced through the posts in this forum - most have to do with XP. (Maybe I should change? That would take days!!!)
    Can anyone out there hook me up? I have a keyboard, wireless optical mouse dongle, camera, GPS antenna, bluetooth dongle, powermate and touchscreen connected to a USB hub with the hub, a DVD drive, and XM connected to my computer USB ports. I've added a 2-USB and 2-firewire hub to the case using the mobo's terminals, but nothing is currently connected to them. The 90 seconds is measured from ign on to music playing. I'm using Frodoplayer, the PC is a P4, 1.8gHz, 1056RAM, 160GB 7200 RPM HDD.
    Any tips or tricks available?
    Update 11/26/05 14:15 ET: Found this webpage outside the forums. Will try it out and see what happens. There are things listed that I KNOW my boot-up can be streamlined with...
    Update 11/26/05 15:32 ET: More good info, here and here. Will try all these and post feedback.
    My first attempt at a carputer.
    PM me if you're interested in a monitor faceplate for your '99-'04 Golf or Jetta. My Vortex ID is NorthAtlR32 - you can IM me there, too. Go here for more information.
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hi there,
    one thing to try is Bootvis. Do a google search for it on the web. This will run defrag and place your boot up files in the best place on your disk for faster boot times. It can make a big impact. I can also recommend doing the minlogin tweak to speed up your boot.
    Good Luck
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Nov 2004
    North Atlanta
    Thumbs up
    Quote Originally Posted by kpjuk
    Thanks for the advice. I'll research those two tips! <charting new territory...(for me, anyway!)>
    Nov 2004
    North Atlanta
    Maybe it's just me... but neither of these appear to be Win2k compatible. Am I wrong?
    Dec 2003
    West Midlands
    Sorry matey, I am on XP, and thought these would work.......
    You are in the right place to ask the question though, got some clever chaps in this place to help sort your problems !
    Have you considered moving to XP ? If you do check out nLite, ultraXP being developed by the guys on these boards.
    Good Luck .... KPJUK
    Nov 2004
    North Atlanta
    I'm starting to consider XP. The downside to the "upgrade" is the amount of time I've already invested getting this machine to run Win2k. I'd be starting from scratch meaning I'd have to spend 10+ hours getting my system back to the same level of functionality as I have now. I FINALLY have all of my software and hardware working together and I don't look forward to starting over...
    Thanks for your help!!!
    Nov 2004
    North Atlanta
    Here's the latest:
    I performed these updates and I'd recommend them to anyone. There's lots of great information. However, it didn't take much time off my boot-up. Roughly 10 seconds.
    I changed the settings in Power Options to allow for hibernation and set Win2k for "hibernation on power switch" input. That cut my reboot time down to 40 seconds. I don't think that's bad considering the amount of items I have running on the USB.
    Comments?
    Dec 2003
    West Midlands
    I'm glad to see that you are making progress. A thing to consider with XP though:
    I am running on a 4200 disk, with an nLite image. This is giving me a boot time of 27 seconds, Hibernation recovery of 11 secs and Standby recovery of 4 secs.
    I am nowhere near the fastest Boot times, others who peruse these boards are down to 15 second boot times using XP, and I guess Standby is almost instantaneous !
    Another thought, have you tried the website that does 98lite and XPlite ? Using a copy of 98lite, I had a 98se image booting in 9 seconds. I am sure that they also do a version for windows 2000, which may be worth having a look at. They are at www.litepc.com
    regards
    KPJUK
    Nov 2004
    North Atlanta
    Thank you... again. :)
    Damn, that's disheartening. And here I was SO proud of my 40 second boot to music time. Thinking out loud... is everyone counting the time from IGN/ACC on or counting the time from motherboard start. My Opus delays start-up by five seconds from receiving an IGN/ACC signal. That means my computer is really booting in 35 seconds - once it's "told to" by the Opus.
    [QUOTE=kpjuk]Another thought, have you tried the website that does 98lite and XPlite ? Using a copy of 98lite, I had a 98se image booting in 9 seconds. I am sure that they also do a version for windows 2000, which may be worth having a look at. They are at www.litepc.com
    You're right, they do - it appears that the XP software is the same piece as the 2000 software. Can it be used after the install? I don't have to start over, do I? Sorry for the ignorance.
    My biggest concern is that I'm chasing my tail. I'm concerned that the reason my boot time is so lengthy is directly attributed to all my USB components. I'd love to hear from someone with nine (or more) USB pcs installed to hear if they're experiencing extended boot times they can't improve. Or, to the contrary, if someone has lots of USB components installed and is booting to music in seconds, it would be nice to know what they've done.
    I'm using Frodoplayer in the start-up menu... wonder if that's increasing my boot time, significantly? Gotta have that loading on start-up, so there's nothing I can do - I'm just thinking out loud. I'm including the time it takes to get music which is a few more seconds after 2000 is booted.
    Sep 2003
    Austin, TX
    Yes, you can use XPLite after the install. All it does is enable you to uninstall optional components...
  1. New EWF + MinLogon and CF instructions
    By SFiorito in forum WinNT Based
    Last Post: 03-12-2010, 01:39 PM
  2. Oh where have all the Shutdown Controllers gone (and boot time)?
    By SuperAJ in forum General Hardware Discussion
    Last Post: 05-21-2005, 09:57 PM
  3. boot problems
    By tracker92 in forum General Hardware Discussion
    Last Post: 05-20-2004, 03:21 PM
  4. Using DOS and 98 at once, can I toggle at boot time with a keypress?
    By bombboyer in forum Software & Software Development
    Last Post: 04-07-2003, 11:13 PM
  5. Enabling/Disabling Setup via boot disk?
    By gizmos in forum Software & Software Development
    Last Post: 07-14-2000, 10:39 PM
