Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: nLite image - Bootvis won't optimize
    Maximum Bitrate kpjuk's Avatar
    Dec 2003
    West Midlands
    Hi guys,
    I have my "working" nLited image pretty stable (v11 !) problem is Bootvis just doesn't want to optimize ! I have downloaded a later version to try that and the same, it does the reboot puts up the sign waiting for bootvis, then closes down!
    Any ideas how to get it to work, I am still at a 27 second boot, and need this little scalpel to shave off a few more seconds !
    So....... any ideas how to get this working, or any other optimiser programs that do a little more than defrag ?!
    cheers
    KPJUK
    M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
    DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
    Raw Wave
    Jun 2004
    On the beach
    There is one component, can't remember which one off the top of my head which is needed by bootvis, it is listed in the warnings when you tick the box in the treeview. Will see if I can find the component for you.
    Dec 2003
    West Midlands
    Cheers Mate,
    I made sure on this version to look out for the Bootvis options, task scheduler was one of these. The download I just tried used an msi package to install bootvis, but this didn't work which surprised me....
    KPJUK
    Raw Wave
    Jun 2004
    On the beach
    Did you remove the windows installer??
    Raw Wave rando's Avatar
    Mar 2004
    Redondo Beach, CA
    IIRC, I had the same problem but it was disk defragmenter that was needed.
    Dec 2003
    West Midlands
    Thanks guys,
    defrag is in, windows installer is out........ is it time for v12 ?
    FLAC SFiorito's Avatar
    May 2004
    you also need System Event Notification Service and the Event Log (Task Scheduler depends on it)
    Raw Wave
    Jun 2004
    On the beach
    Dec 2003
    West Midlands
    Looks like I will need to fatten this little install......
    Thanks for the advice on the CF card install by the way. It seems to be 2 seconds faster on boot up ! The main advantage though is that you can protect the boot image from changes by usning EWF. I changed the %userprofile% variable to c: in the nLite tweaks, and now when I move over to the CF image on drive E, it still makes any change to docs & settings on c:, so keeps the change requests down to a minimum.
    Ah well, Man Utd v Chelsea beckons, I will get the new image built while its on....
    cheers
    guys
    KPJUK
    Dec 2003
    West Midlands
    Talking
    Thanks SFiorito,
    SENS, Task Scheduler and Event log are in, just needs Windows installer by the look of things !
    v12 is on its way.....
  1. nLite making me nSane: Frodoplayer issue
    By Nobias in forum WinNT Based
    Last Post: 01-13-2005, 12:09 AM
  2. Replies: 2
    Last Post: 01-05-2005, 07:22 AM
  3. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 02:22 PM
  4. Lilliput no image
    By linzhang in forum LCD/Display
    Last Post: 11-02-2004, 08:02 AM
  5. DWW-7VGA won't display image
    By guf in forum LCD/Display
    Last Post: 05-08-2004, 05:06 PM
