Results 1 to 10 of 11
Thread: minlogon with a diff shell other than explorer.exe
    Newbie syfenx's Avatar
    Jan 2005
    a place in TX
    how is this done?
    i tried to replace "shell = explorer.exe" in the registry.. (search for "shell")
    i replaced it with a blank vb app just to test it, and it works, but! if you try to close the app it immediately re-opens itself.. thats the bad part
    i just ctrl alt del.. opened regedit.. and i changed it back.. but what if i want to use litestep as the shell.. there has to be a way around this.. there is a way around everything..
    bottom line..
    find a way to use another shell or set a program as the shell other than explorer.exe while using minlogon (this is a minlogon setup without EWF running on a normal desktop.. its not nlited or anything)
    FLAC SFiorito's Avatar
    May 2004
    This has been covered before actually. There's another reg value under the winlogon that defaults to restarting the shell when it is closed (in case of a crash). Just change the value (AutoRestartShell I think it was...)
    Jan 2005
    a place in TX
    i know about the autorestartshell, but i disabled it and it still does it, i made a point to disable it before, but i tried it with a blank vb app i compiled.. just to test it and it loads yes, does it ever close.. no.. it just keeps reopening..
    i HAVE to figure this out..
    May 2004
    What value did you enter for AutoRestartShell?? I've used it before with no prob... Try just using cmd.exe as the shell to see if it's something having to do with your VB app.
    Jan 2005
    a place in TX
    the entry was set to autorestartshell = 1 by default, so i set it to "0" to turn it off..
    open vb.. normal exe.. and just a regular normal form with 0 lines..
    i compiled it as a test.. and thats it.. i set that..
    and i restarted.. but its still having that problem
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    GPEDIT.MSC, User configuration->SYSTEM->Custom User inter face, then type in the path of your "interface or front end"
    This is what I do with minlogon, works great !
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Jan 2005
    a place in TX
    does this work for sure? is it tested? if thats a fix that works, its gonna be nice in my case and alot of people i will test it when i get home..
    thanks..
    Jun 2004
    NH
    yup works for sure, make sure that you have the .EXE path correct. Example:
    mine is set to: c:\program%20files\master%20control\Masterconsol5. exe
    it loads this instead of Explorer.exe (windows GUI) Be careful though, because if CTRL + ALT + DEL isnt working, you will have no way to get back to your windows GUI. So make sure you have a way to run "Explorer.exe" or GPEDIT.MSC once Explorer Shell is disabled.
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Jun 2004
    NH
    Ok, I'd frist like to say: "CRAP" sorry about that last post I had. With MINLOGON enabled changing GPEDIT's custom UI will not work, you gotta actually change the registry... make sure you got a way to change it back however if your just testing to see if it'll work...
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    Jun 2004
    NH
    Addition
    In addition to all of this to you programmers that load a front end but still need a way to run an app undernieth your front end.. or even to launch explorer.exe here's a great article from MSDN, click on the example.. you can write a Shell app. (just like start->run on explorer) with 2 lines of code...MSDN
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  1. Replies: 268
    Last Post: 05-28-2012, 10:49 AM
  2. minlogon experiment gone wrong for a sec
    By syfenx in forum WinNT Based
    Last Post: 01-23-2005, 10:41 PM
  3. What windows shell are you using?
    By Quattro in forum General MP3Car Discussion
    Last Post: 11-24-2004, 08:21 PM
  4. Need help executing an EXE on startup when I have CobraIII as the shell
    By Adam F in forum Software & Software Development
    Last Post: 04-26-2002, 09:12 AM
  5. new windows shell & 'shell=' for win2K
    By magnetik in forum Software & Software Development
    Last Post: 04-16-2002, 09:47 PM
