Results 1 to 10 of 13
Thread: taskbar popups
    Constant Bitrate forevertheuni's Avatar
    Jul 2004
    Portugal,Mealhada
    taskbar popups
    guys I have lot of pop-ups of that baloons in the taskbar in my winXP....it's very anyoiing ..ah by the way when my MapMonkeylauncher.exe starts(inside frodoplayer) the taskbar comes out...what can I do?..especially about the baloons
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    Quote Originally Posted by forevertheuni
    needle ......
    Jun 2004
    AZ
    Looks like chun-lee needs an needle too.....I like the avatar
    You could just disable the balloon tips....
    How to disable balloon tips in Windows XP:
    http://support.microsoft.com/default...307729&sd=tech
    Variable Bitrate Grimey's Avatar
    Feb 2005
    Moody, ME
    If you have a lot of stuff in your taskbar that is booting when you load windows just do
    start -> run -> msconfig -> click on startup tab and uncheck things you don't want.
    the balloon idea is a good one too.
    Dak TruckPuter:
    Mac: - Researching and Awaiting Funds
    Changed to planning for a Mac Mini Trukputer...w3rd.
    Oct 2004
    South Carolina
    good information, saved for later use !
    Jul 2004
    Portugal,Mealhada
    tnx for tip
    tnx for the tip...the baloons that keep anoying me were the "Your computer is @ risk"....I ****ed of so many times
    In a world without Gates and Windows there are no fences or walls!!
    Maximum Bitrate TimmyM's Avatar
    Aug 2003
    Federal Way, WA
    thats from the Security Center and you can turn that one off by going to control panel/security center/change the way Security center alerts me I believe. don't remember for sure since i have it turned off Or install Antivirus. Which would solve that and maybe some other problems.
    Res Master
    SP2? RUN -> CONTROL -> SECURITY CENTRE -> CHANGE THE WAY SECURITY CENTRE ALERTS ME -> DESELECT THEM ALL. You will no longer be warned about windows updates, inadequate firewall or antirus protection.
    BIOSTAR M7NCG400 : AMD-M ATHLON XP 2400+ : VANTEC AIRFLOW : 512 MB 3200 RAM : XENARC 700TSVB : MSI 128MB DDR MX4000 : MONSTER 300 WATT INVERTER
    Res Master
    I was two seconds too slow on my reply, sorry
  1. Taskbar all F'ed up .... XP related
    By Don 944 LA in forum Software & Software Development
    Last Post: 12-02-2004, 11:22 AM
  2. [WinXP] How to disable loading settings popups
    By _wd in forum Software & Software Development
    Last Post: 11-19-2004, 03:30 PM
  3. Taskbar keeps appearing
    By knubile in forum Map Monkey
    Last Post: 11-17-2004, 10:38 AM
  4. why does my taskbar show when i run gps???
    By TheKurbster in forum FrodoPlayer
    Last Post: 11-10-2004, 08:36 AM
  5. making taskbar items larger?
    By aoLhaTer in forum Software & Software Development
    Last Post: 01-15-2004, 06:46 AM
