Page 1 of 3 123 LastLast
Results 1 to 10 of 27
Thread: CF fixed disk utility
    Does anyone have the utility that tells a CF card that its a fixed disk drive? I believe its called atcfwchg.com
    I've cant seem to run bootprep on my 1GB cf card. It keeps saying the drive is protected. I can fdisk and format it though. Anyone have this file? Thanks
    FLAC SFiorito's Avatar
    May 2004
    what card do you have? I've run bootprep on removable drives before and I never got such an error. are you using a 40 conductor cable with your ide adapter?
    I have a SanDisk Ultra II 1GB, using the CF slot built into my mobo, its using the slave position on the secondary IDE channel. Its a permission error of some kind. I can see the CF as if it were a fixed disk in DOS, but in windows is still shows as a removable drive. Is this correct?
    May 2004
    yeah, it's just Windows that has the issue with fixed vs removable. what letter does your drive get assigned? whichever that is, that's what you need to use, i.e. "bootprep /dn" n being your drive letter. your mobo's cf slot doesn't have some kind of write protection does it? you sure the cf slot is on the IDE bus, right?
    I'm running bootprep correctly, its assigning C to the drive. I wouldnt think its write protected if I can fdisk and format it. The CF slot is on the secondary IDE channel, I've tried master and slave. Do you have that utility?
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    What system board to you have ? If MII10000 then I don't think BIOS will see the drive as an IDE device.. therefore poot prep wont work..
    edit: If my hardware has arrived I'm doing this tonight... I hope it goes smoothly !
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    My board supports booting from the CF slot. I just need the utility.
    Jan 2006
    I'm in need of this too, I'm using the slot built into my MB, I can boot to it, but need to mark it as fixed. could someone send it to me please
    Sep 2005
    Didn't notice this thread.....
    I'm would like a copy of the utility too.
    michaelergud at gmail.com
    /Michael
    Dec 2006
    I could use a copy of this too if it's still going around.
    gregwoods2k at gmail.com
    many thanks
    //gman
  1. Flash card bootable drive?
    By The Durango Kid in forum General Hardware Discussion
    Last Post: 03-16-2005, 09:20 AM
  2. Sandisk Extreme III cannot be set to fixed disk
    By knubile in forum WinNT Based
    Last Post: 01-06-2005, 03:01 PM
  3. XP Pro on CF card working!!
    Last Post: 01-03-2005, 07:48 PM
  4. Flash OS
    By BiohazrD in forum General Hardware Discussion
    Last Post: 12-04-2004, 09:57 AM
  5. Fixed disk 0: Fujutsi .....
    By Jaymz in forum General Hardware Discussion
    Last Post: 03-04-2001, 02:26 PM
