Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: blue boot screen
  1. #11
    Nov 2004
    New York
    Well, I'm not sure what most of this means... I would greatly appreciate it if you can explain it a little clearer in 'laymans' terms. I also copied exactly what the screen says:
    A problem has been detected and windows has been shut down to prevent damage to your computer.
    Unmountable_Boot_Volume
    If this is the first time you have seen this stop error screen, restart your computer. If this screen appears again. follow these steps:
    Check to make sure any new hardware or software is properly installed. If this is a new installation, ask your hardware or software manufacturer for any windows updates you may need. If problems continue, disable or remove any newly installed hardware or software. Disable BIOS memory options such as caching and shadowing. If you need to use safe mode to remove or disable components, restart your computer, press f8 to select advanced startup options, and then select safe mode.
    Technical information:
    *** stop: 0x000000ed (0x84f4f030,0xc0000032,0x00000000,0x00000000)
    Quote Originally Posted by DarquePervert
    I had something serious happening with a client. It turned out to be a bad stick of RAM that caused rebooting so much that Windows was booched.
    Since the 'serious error' was coming up before you booched the monitor, I'd say that you've got a hardware problem, but maybe not.
    Boot to your Windows CD and go into the repair console and run a CHKDSK /R. It'll take some time. It took about an hour on a client's P4 3Ghz box, and there was damaged data. Let it run and don't watch it. It's boring as all hell.
    If that doesn't work, try re-installing the OS from scratch. Re-format the partition where Windows install, and don't use the Quick Format.
    If that doesn't work, you're going to need to start replacing components one by one until the problem goes away.
    I'd try the RAM first, since it's the easiest to replace.
    If the RAM is good, then try a new hard drive.
    Next would be the CPU, if it's not hard-wired like on the EPIA motherboards or a laptop board. Make certain you clean the CPU using rubbing alcohol and apply a thin coat of quality thermal grease like Arctic Silver.
    If that's good, then look at power supply. That's a PITA in your car, I know.
    Lastly, the motherboard.
    Good luck. I hope you figure it out, man.
  2. #12
    Nov 2004
    New York
    bump
  3. #13
    FLAC SFiorito's Avatar
    May 2004
    try attaching the drive to another PC and see if you can access it from there. If not, then most likely the drive is bad. Happened to me before with my laptop drive.
  4. #14
    Nov 2004
    New York
    Well, everyone....I fixed the problem. Somehow a registry became corrupted, and i needed to run my windows cd and repair. The reason windows was not booting up so I could run the repair was because it was a usb cd player. It was a fair amount of work to connect another cd drive, due to my installation, but I got it. Everything seems fine now, except of course for that damn 'your system has recovered from a serious error' messege that appears every time I start the computer......any other suggestions for that one? This messege appears even if I shut down the computer correctly through windows.
  5. #15
    Nov 2004
    New York
    Guess what...I found this excellent tool called Google, and after investing approx. 14 seconds, I found the solution to my serious error messege. I suggest that everyone tries this site www.google.com -It is extremely helpful!
  1. WinXP Boot Screen
    By FRP in forum Software & Software Development
    Last Post: 10-17-2004, 02:34 AM
  2. TM-701L Problem Issue - Screen goes dead
    By Cliff in forum LCD/Display
    Last Post: 03-11-2004, 02:44 PM
  3. BMW pre-installed system - TFT ?
    By tsingsu in forum LCD/Display
    Last Post: 08-05-2002, 03:16 AM
  4. Replies: 13
    Last Post: 07-02-2002, 11:54 AM
  5. screen help
    By XCURSN in forum LCD/Display
    Last Post: 06-24-2002, 12:10 PM
