Results 11 to 20 of 29
Thread: nLite XP, CF card, VIA mobo, Bumbed out
  1. #11
    Registered User mpattonm's Avatar
    May 2003
    Czech rep.
    I am testing my mockup in these days, its about minus 10 here.
  2. #12
    Maximum Bitrate knubile's Avatar
    I didn't know the EPIAs had a temp saftey feature. Mine will boot up no matter how cold it is. It's get's to -30C regularly here in Ottawa, Canada.
    The problem I encounter is after the post. At the point where the windows logo appears, it reboots. Then boots back to the same point, then reboots again.
    It will keep doing this until it is warm enough, the it continues on to Windows.
    I have yet to figure out which part of my system is the culprit.
    I have a 1G Sandisk Extreme. I know it's not rated at that temp, but it passes post and starts loading windows. That means its reading from the CF card. The ram must be getting used at that point. So what's left?
    What does your system do exactly?
  3. #13
    May 2003
    Czech rep.
    Possibly PSU could be weakest point.
  4. #14
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    When testing its gotta sit there all night in the cold cant just be a few hours.
    as far as changing over to .Net, I like the functionality it gives. As far as programming I needed to learn it for my job and I fig'd what better way to get a good hands on and change my existing front end to .net, that way I can learn the language and acomplish my car stuff at the same time :-)
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  5. #15
    Oct 2003
    Chicago, IL
    yeah, .net is kinda slowish but it makes programming stuff alot easier and the functionality is pretty cool, so i can understand why someone would want to switch to .net
    Mazdaspeed Car Computer
    gotta redo it all
  6. #16
    It's only slow if you don't know what you're doing.
    Keeping with good programming practice, a .NET application will run just as fast as you expect any windows application.
    It all just depends on the application itself. The overhead from the VM isn't what makes things take so long to load. It just depends on what the application is doing.
  7. #17
    FLAC SFiorito's Avatar
    May 2004
    there are tons of articles on MSDN about optimizing .NET apps. People using .NET should read them. They are there for a reason. Like I posted in the Centrafuse forum for instance, you can install a native image of your .NET app in your GAC which can speed up the app startup time significantly.
  8. #18
    Jul 2004
    @Knubile: So what temperature will your system do the reboot thing at?
    I'm gonna be really dissapointed if I've spent all this time on a CF install only to find out that the PSU, mobo, etc don't work below 0 degrees...
  9. #19
    Jun 2004
    NH
    dont go smashing your head against the wall.. but I think that is the case.. happened to be again today... 0 all night 7-10 when it booted waited about 10 minutes for car to warm up.. and booted just fine..
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  10. #20
    Oct 2003
    Chicago, IL
    Quote Originally Posted by SFiorito
    good info. i will look for those articles, thanks!
    gotta redo it all
  1. Slimline Slot DVD/Wafer Mobo and XP
    By Cyberphox in forum Classified Archive
    Last Post: 03-29-2004, 10:01 AM
  2. FS: Slimline CD & DVD, 512MB CF Card
    By StratusPh34r in forum Classified Archive
    Last Post: 01-31-2004, 09:31 PM
  3. FS: Athlon XP +1700 CPU and A7V8X-X mobo
    By samc in forum Classified Archive
    Last Post: 11-03-2003, 08:03 AM
  4. help - video card problems
    By Cliff in forum General Hardware Discussion
    Last Post: 04-15-2002, 06:25 PM
  5. TV Out Card Requires Mobo Reset
    By Oldschool in forum General Hardware Discussion
    Last Post: 12-15-2000, 10:49 AM
