did you install minlogon using the new procedure? all you did to the registry was add a single config value, right? if you still have a back up of winlogon in your system32 directory then just switch back to winlogon (there may be some problems with installing new hardware using minlogon). once you do that you can just hit ctrl-alt-del to bring up task manager and just use file->run to start explorer.exe or bring up regedit to restore explorer as the shell.
LinkBack URL
About LinkBacks
