good q. i want to know too. Like if you exit RR does it just bring you back to windows if you loaded it as your shell?
I want to choose Road Runner as my start up shell, but I want the option to use windows as well. Is there a way I can choose when I boot? like having multiple versions of windows? also If I do change Road Runner to my shell, will it load everything correctly, ex. navivoice, codecs, phonecontrol, etc.
Peep MY TYTE WHIP yo! It's got too many ill mods to list!
if the frontend supports starting an external application then you can do that, otherwise you can only use explorer or your frontend as the shell. you could also write a small applet that runs as your shell which in turn starts up either explorer or your frontend. that way when you exit your shell the applet is there for you to start explorer. or you could just hit ctrl-alt-del and run explorer from task manager. keep in mind that if you're using minlogon that you'll need the ctrl-alt-del service posted as a sticky in this forum.
well, that's completely different. that's the bios (or an addon to it) that does that. i think it's in one of those new palmtop PC's. you can even check email on it without booting into Windows.
ah ok I just made an app called WINDOWS for rr and in the ini i put:
[GENERAL]
PATH = C:\windows\explorer.exe
TryEmbeddedTimeOut = 5
WindowSearchString=!ExploreWClass
Seems to work cool.
OK one question, when I am in regedit and I go to:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
and then edit Shell, what do I put in there? It says "explorer.exe," but do I have to put the whole path like: C:\Program Files\Road Runner\rr.exe
Would that work?
Scared to mess it up thanks!
Will work just fine
I'm doing the exact same thing
1984 BMW 323i (E30)
[==========] 90%
EPIA MII10000
256MB RAM
40GB 2,5" HD
Lilliput 7" TS
Hacked Travla C134
Haicom CF GPS
so i put the whole path? sorry, just checking one more time, wasn't sure if you meant the app or the filepath...
The whole path, yeah.
Ie. "C:\Program Files\Road Runner\rr.exe"
1984 BMW 323i (E30)
[==========] 90%
EPIA MII10000
256MB RAM
40GB 2,5" HD
Lilliput 7" TS
Hacked Travla C134
Haicom CF GPS
Sweet thanks! hey you don't know how to change/move the progress bar on the startup screen do you? I made a cool one, but not sure how to move it where I want and get it to load in windows.....
