Results 1 to 10 of 11
Thread: any chance to "hide" windows
    Constant Bitrate cyberlancer's Avatar
    Feb 2005
    Gallarate (VA) - Italy
    hi, i'm afraid it's not a so clever question, but: is there any chance to hide windows and start directly with the chosen front end? i mean, is there a way in order to do this:
    1. avoid all post text and messages to be shown (just black screen could be good),
    2. use a custom boot logo (i've already done this)
    3. enter directly the front end, without see any windows trace?
    thanx.
    Admin. Linux loser.
    Bugbyte's Avatar
    Corning, NY
    Blog Entries
    2
    Search on terms like "windows shell" or "using FP as shell". I'm not sure you can do everything you're asking, but you can do some of it.
    Want to:
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Yes you can do this, you cant even tell my carpc is windows as it boots straight into the frontend with no messages (apart from the boot logo of course)
    You need to tell Xp to autologin
    Set your shell to be your frontend rather than explorer
    There is a local policy setting to disable windows status messages ("Opening network connections" and all that jazz). Once activated nothing will be shown at all apart from the default background until the frontend has loaded
    Use TweakXP to change the default "login" background to black. This will mean after the boot screen all you will see is a black screen until your frontend appears.
    Easy as that!
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    FLAC SFiorito's Avatar
    May 2004
    look at: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon
    and modify the Shell registry value to your front end. Make sure you've got a way to bring up explorer or a command line once you make this change.
    Feb 2005
    thanx alot. quick, sharp and clear!
    only a little doubt: how about hiding motherboard post messages (press del to enter setup, irq listing and so on ... without having to delay monitor power on, i mean...).
    May 2004
    your bios may have a "silent" boot option where it displays an image rather than the post messages. mine has it, but intel recommends not using it if you want the fastest boot possible. some even let you change the image.
    Well, He asked for it. WebDog's Avatar
    Los Angeles, CA (West LA)
    Quote Originally Posted by SFiorito
    any idea how to get back into explorer.exe?
    1990 Jeep Cherokee
    2000 VW Golf TDI 4dr
    2005 VW GTI MKIV - SOLD
    Jan 2003
    Ruston, LA
    Quote Originally Posted by WebDog
    just tell your frontend to open explorer.exe as an app
    or use the task manager to run it
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    careful tho if your using minlogon.exe CTRL, ALT, DEL will be disabled.. so make sure your front end has a shell capability.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Quote Originally Posted by frodobaggins
    hmm il have to try that on my laptop im albout ready to load linux on so it wont matter if i jack it up.
    if i do that and it dont work would safe mode work? or would that go to the Front end to?
    Would their be any proformance gains by not loading explorer?
    Hmm the big question, What front end to use lol.
    1990 Jeep Cherokee
  1. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 11:54 AM
  2. Poll: Windows version of HeadUnit needed?
    By NoPistonPC in forum Software & Software Development
    Last Post: 09-23-2004, 04:22 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 12:40 AM
  4. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 01:30 PM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 09:11 AM
