Page 2 of 2 FirstFirst 12
Results 11 to 18 of 18
Thread: windows xp install
  1. #11
    Super Moderator xBrady's Avatar
    USA
    Quote Originally Posted by Moneyfink
    what is "ide hdd block" in my bios, and it is currently set as enable should i change that?
    You want that on. That speeds up your hard drive access.
    Installed.
    -GPSSecure- - GPS Tracking
  2. #12
    Elsewhere
    You need to break out the manual for your motherboard and read what all the BIOS options are.
    How about the Wiki?
  3. #13
    Variable Bitrate Moneyfink's Avatar
    Feb 2005
    S Ohio
    i got the board on ebay.. no manual... google hasn't been very helpful either.
    I am going to try to install windows 98 on the computer today because it is fairly old (2001) and it may not like xp.
    My OLD carputer page
    My NEW carPC
    Via Epia M10000, 512 PC2100, Opus 150, 8" lilly touch, 320 GB 7200 WD Caviar
  4. #14
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    if you are installing windows 98, do you have a floppy drive? for what i know original win98 doesnt boot from cd, so you need a boot disk to get to dos. also you can try to make a bootable cd and burn win98 with it if you dont have floppy drive. thought of installing that on my carputer but i dont think in this age, win98 can keep up with all the things you want in your computer, i usually had problems with my devices that is why i switched to win2000 pro or xp.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  5. #15
    USA
    Did you find the boot sequence in your BIOS?
    Installed.
  6. #16
    Feb 2005
    S Ohio
    thank you guys, i have got it working now, im actually typing on my carputer right now. (although its in my house) my 5 year old hardware did not like xp, so i anstalled windows98, then upgraded.
    thanks again.
    now to get that boot time below 90 seconds.. how much will more ram help?
    My NEW carPC
  7. #17
    Feb 2005
    ca
    post again when you are done installing win98, i wanna know if you get problems with bluetooth, wifi and other hardwares
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  8. #18
    Feb 2005
    S Ohio
    I installed windows 98 and went very quickly and was easy. Then while windows was running I inserted A windows XP disk, and clicked upgrade, instead of fresh install. everything went very smoothly, and now i have xp on a 5 year old mobo. I am now just installing drivers and transfering my 100.78 gb of mp3's. Sorry i can't help you with your win98 question b/c i only ran win98 for a few minutes
    My NEW carPC
  1. Anyone ever changed the hibernation Windows XP screen?
    By clean customs in forum WinNT Based
    Last Post: 11-04-2010, 09:04 AM
  2. Windows XP w/wireless Linksys USB vs NetStumbler trying to wardrive
    By clean customs in forum Wireless Communications
    Last Post: 01-07-2009, 12:18 PM
  3. installing windows xp or 98 on 1GB CF
    By arise360 in forum Software & Software Development
    Last Post: 11-11-2004, 07:13 PM
  4. windows 2000, xp and EPIA 800
    By samc in forum General Hardware Discussion
    Last Post: 08-24-2003, 09:41 PM
  5. Windows XP power option for Shutdown. Circuit design help.
    By LESLIEx317537 in forum Power Supplies
    Last Post: 02-03-2002, 10:42 AM
