Page 2 of 16 FirstFirst 123456789101112 ... LastLast
Results 11 to 20 of 156
Thread: Safe nLite setting.ini
  1. #11
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I'm not sure how to do this with the newer nLite as I dont havce it on my machine. But if you print out the settings.ini file and just compare the list it would only take about 5 minutes.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  2. #12
    FLAC SFiorito's Avatar
    May 2004
    to integrate minlogon or ewf into an nLite installation: http://www.mp3car.com/vbulletin/show...01209#poststop
  3. #13
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    so your settings.ini doesn't work with the new nlite? anyway to make it work exactly?
    Thanks for the minlogon link!
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  4. #14
    Jun 2004
    NH
    Probably not w/ the new nLite. You can however use the list of things to use as a guide. I was just too lazy to make a new list so I just posted my settings.ini as the "guide"
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  5. #15
    Jun 2004
    nyc
    Great Work! Thoes who have fiddled with Nlite know how difficult and tidious it is to get the "right trimming". I've been meaning to post someting like this to share with others but haven't been confident to post my setting.
    I encourage everyone to join this and share their setting. More people join, better it will be.
  6. #16
    Jun 2004
    NH
    Quote Originally Posted by mi800
    To second this comment, I've made about 30 different versions w/nlite testing each one throughly for the most stable system. Just take a gander at how long this has taken me ?? 100+ hours
    I figure these settings will be a great safe starting point if others can post more findings that would be great !
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  7. #17
    Feb 2005
    The Yay Area (SF)
    thanks man works great I just looked at your settings and the new lite has tons of options too, I love my carpc now its fast as @#$#
    But I have one problem.
    my sound drivers won't install right I get an error:
    error loading loading streamci
    the specified module coudl not be found.
    winamp messes up because of this
    I believe it is because you didn't have the midi driver checked in nlite
    I got the files from my other pc and it works fine now
  8. #18
    Jun 2004
    NH
    Yup.
    Yup your right, I dont use winamp so I wouldnt have known that also I'm not really into "midi" files either... But thanks for pointing that out...
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  9. #19
    Feb 2005
    The Yay Area (SF)
    oop scratch this.
  10. #20
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    did you ever tried installing and running phone control under this settings? im out of my luck trying to make nlite and phone control work. any help is good. thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 03:22 PM
  2. nlite requirements for FrodoPlayer
    By knubile in forum FrodoPlayer
    Last Post: 12-02-2004, 08:22 AM
  3. Replies: 0
    Last Post: 05-18-2004, 08:38 PM
  4. Disabling safe mode in Windows ME?
    By Squeezer in forum Software & Software Development
    Last Post: 02-13-2001, 12:51 PM
  5. Win 98 safe mode
    By snakebite in forum General Hardware Discussion
    Last Post: 10-03-1999, 01:09 PM
