Page 3 of 16 FirstFirst 12345678910111213 ... LastLast
Results 21 to 30 of 156
Thread: Safe nLite setting.ini
  1. #21
    Maximum Bitrate contaygious's Avatar
    Feb 2005
    The Yay Area (SF)
    mine is workign so far under these settings. I'm having a problem with the talking/hearing people. but I can pick up/call/see pheonbook etc. did youuse these settings when u nlited?
    Peep MY TYTE WHIP yo! It's got too many ill mods to list!
  2. #22
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    Didn't try pho-co with my settings. Make sure to download and install this: http://www.microsoft.com/downloads/d...displaylang=en
    Its the .Net redistributal package it will enable applications written in .Net to work properly.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
  3. #23
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    i already downloaded that, but after i installed the os, .net 1.1 and phoco, i still get errors like the ones posted by zorro. did you use this settings on yours contagious? did you add anything or remove anything aside from the settings posted?
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  4. #24
    Feb 2005
    The Yay Area (SF)
    well i didn't remove anything that looked network/bluetooth related in that list. sorry i dont remember exactly.
  5. #25
    Jul 2004
    Denmark
    How do i install this on a system NOT able to boot from CD ??
    Normally it's possible to use cdrom:\i386\winnt.exe
    but the winnt.exe is missing in nlite........
    Car PC: Via Epia M10000N ~ Morex Cubid 2699 ~ M2-ATX PSU ~ 512 MB DDR Kingston ~ G-Sat BU-303 GPS mouse ~ 80 GB Samsung 3.5" hdd ~ Ruwido Wireless IR Keyboard w/mouse keys. ~ 7" - MM400 Touch Screen
    www.autopc.dk
  6. #26
    I used your setup file IntellaWorks. I had to do a little cutting and pasting since I used a newer version of nlite and an older build of XP. It works great. Nice and trim and fast. there's only 2 things I'm missing that I need- I have mo msinfo.exe and I lost the icon in the task bar that brings the desktop back when I click on it. Other than that, your settings got me what I wanted without a lot of experimenting. Thanks!
  7. #27
    Jun 2004
    NH
    Quote Originally Posted by turbochris
    Great to hear some positive feedback, your very welcome. Sorry that you have to cut and paste the settings but the newer version of nLite farks my machine so I just cannot install it right now, there fore cannot post. Maybe you guys could post the equilivent of my settings.ini to the newer version ?
    As far as msinfo.exe & desktop ico I have no clue where to begin. Did you slipstream minlogon and ewf into the install ?? If so those guys definatly wont be available.
    I'm not even using explorer (the standard windows shell) I'm going to use my front end instead and really if you guys went this far to shave down XP you might as well follow suit and do the same.
    If you REALLY need these two things then your prolly gunna have to search for em'. The thing with dealing with nLited OS's is that your doing things to the OS that makes it act completely different and sometimes MSDN and MS support doesn't always apply but still worth a look. But thats where the fun begins. You'd be suprised how much time it could take to figure that stuff out.
    I've got too many hours to count invested in this settings.ini...
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  8. #28
    msinfo isn't a big deal, show desktop I'll figure out but neither is worth a reinstall. My system works great, I like it so much I backed it up on a cd and put it under my pillow. This was part of an upgrade from 2K. My old soundblaster awe64 gold sounds better under XP.
    Here's my setup file, there's some extra settings on the end. I just put your setup file next to a setup file made with my os using the lite settings, I cut and pasted the conflicts like the build number and the different names of the setting groups and the extra settings at the end I just used whatever looked good. How did you get that scrollable window? I thought I knew all the code already.....
    [Main]
    Env = 0.99.8 beta 5.2032.Microsoft Windows NT 5.1.2600.0
    Target = Windows XP Professional SP1 - build 1106 - English (United States)
    [Tasks]
    Remove Components
    Unattended Setup
    Options and Tweaks
    Create a Bootable ISO
    [Components]
    ;# Applications #
    Accessibility Options
    Briefcase
    Calculator
    Charmap
    ClipBook Viewer
    Defragmenter
    Games
    Internet Games
    NT Backup
    Pinball
    Screensavers
    ;# Drivers #
    Battery
    Cameras and Camcorders
    IBM Thinkpad
    InfraRed
    ISDN
    Modems
    Multi-port serial adapters
    Portable Audio
    Printers
    Scanners
    SCSI/RAID
    Toshiba DVD decoder card
    Windows Image Acquisition (WIA)
    ;# Internet Utilities #
    Client for Netware Networks
    FrontPage Extensions
    Internet Connection Wizard
    Internet Explorer
    Internet Information Services (IIS)
    MSN Explorer
    Netmeeting
    NetShell Cmd-Tool
    NWLink IPX/SPX/NetBIOS Protocol
    Outlook Express
    Synchronization Manager
    Vector Graphics Rendering (VML)
    Web Folders
    Windows Messenger
    ;# Multimedia #
    Images and Backgrounds
    Luna Theme
    Media Center
    MIDI audio support
    Mouse Cursors
    Movie Maker
    Music Samples
    Old CDPlayer and Sound Recorder
    Speech Support
    Tablet PC
    Windows Media Player
    Windows Sounds
    ;# Operating System Options #
    Administrator VB scripts
    Desktop Cleanup Wizard
    Disk Cleanup
    DR Watson
    File and Settings Wizard
    Floppy Support
    Help
    Input Method Editor
    Manual Install and Upgrade
    MS Agent
    Printer Support
    Search Assistant
    Service Pack Messages
    Shell Media Handler
    Task Scheduler
    Tour
    Web View
    Zip Folders
    ;# Services #
    Alerter
    Application Layer Gateway
    Autoupdate
    CTF Loader
    Distributed Link Tracking Client
    DNS Client
    Error Reporting
    Fax Services
    Imapi
    Indexing Service
    IPSEC Policy Agent
    Messenger
    Network DDE
    QoS RSVP
    Remote Registry
    Removable Storage
    Secondary Logon
    Service Advertising Protocol
    SNMP
    System Restore
    TCP/IP NetBIOS Helper
    Telnet Server
    Terminal Services
    Uninterruptible Power Supply
    Universal Plug and Play
    Volume Shadow Copy
    WebClient
    Windows Time
    ;# Languages #
    Afrikaans
    Albanian
    Arabic (Saudi Arabia)
    Arabic (Iraq)
    Arabic (Egypt)
    Arabic (Libya)
    Arabic (Algeria)
    Arabic (Morocco)
    Arabic (Tunisia)
    Arabic (Oman)
    Arabic (Yemen)
    Arabic (Syria)
    Arabic (Jordan)
    Arabic (Lebanon)
    Arabic (Kuwait)
    Arabic (U.A.E.)
    Arabic (Bahrain)
    Arabic (Qatar)
    Armenian
    Azeri (Latin)
    Azeri (Cyrillic)
    Basque
    Belarusian
    Bulgarian
    Catalan
    Chinese (Taiwan)
    Chinese (PRC)
    Chinese (Hong Kong S.A.R.)
    Chinese (Singapore)
    Chinese (Macau S.A.R.)
    Croatian
    Czech
    Danish
    Divehi (Maldives)
    Dutch (Netherlands)
    Dutch (Belgium)
    English (Australia)
    English (Canada)
    English (New Zealand)
    English (Ireland)
    English (South Africa)
    English (Jamaica)
    English (Caribbean)
    English (Belize)
    English (Trinidad)
    English (Zimbabwe)
    English (Philippines)
    Estonian
    Faeroese
    Farsi
    Finnish
    French (France)
    French (Belgium)
    French (Canada)
    French (Switzerland)
    French (Luxembourg)
    French (Monaco)
    Galician (Spain)
    Georgian
    German (Germany)
    German (Switzerland)
    German (Austria)
    German (Luxembourg)
    German (Liechtenstein)
    Greek
    Gujarati (India)
    Hebrew
    Hindi
    Hungarian
    Icelandic
    Indonesian
    Italian (Italy)
    Italian (Switzerland)
    Japanese
    Kannada (India)
    Kazakh
    Konkani
    Korean
    Korean (Johab)
    Kyrgyz (Kyrgyzstan)
    Latvian
    Lithuanian
    FYRO Macedonian
    Malay (Malaysia)
    Malay (Brunei Darussalam)
    Marathi
    Mongolian (Mongolia)
    Norwegian (Bokmal)
    Norwegian (Nynorsk)
    Polish
    Portuguese (Brazil)
    Portuguese (Portugal)
    Punjabi (India)
    Romanian
    Russian
    Sanskrit
    Serbian (Latin)
    Serbian (Cyrillic)
    Slovak
    Slovenian
    Spanish (Traditional Sort)
    Spanish (Mexico)
    Spanish (International Sort)
    Spanish (Guatemala)
    Spanish (Costa Rica)
    Spanish (Panama)
    Spanish (Dominican Republic)
    Spanish (Venezuela)
    Spanish (Colombia)
    Spanish (Peru)
    Spanish (Argentina)
    Spanish (Ecuador)
    Spanish (Chile)
    Spanish (Uruguay)
    Spanish (Paraguay)
    Spanish (Bolivia)
    Spanish (El Salvador)
    Spanish (Honduras)
    Spanish (Nicaragua)
    Spanish (Puerto Rico)
    Swahili
    Swedish
    Swedish (Finland)
    Syriac (Syria)
    Tamil
    Tatar
    Telugu (India)
    Thai
    Turkish
    Ukrainian
    Urdu
    Uzbek (Latin)
    Uzbek (Cyrillic)
    Vietnamese
    ;# Compatibility #
    [KeepFiles]
    [RemoveFiles]
    [Options]
    ClassicSetup
    BlackSetupBack
    OemBranding
    ProfilesDir = "%SystemDrive%\Documents and Settings"
    ;#ISO maker#
    isovol = WInLITE
    isoatt = -allow-multidot -relaxed-filenames -allow-leading-dots -N -l -d -D -joliet-long -duplicates-once -no-emul-boot -b boot.bin -hide boot.bin -hide boot.catalog
    [Tweaks]
    ;# Desktop,Taskbar & Startmenu #
    Disable Group similar taskbar buttons
    Disable Hide inactive icons
    Disable Highlight newly installed programs
    Disable Start Panel popup on first boot
    Do not use Personalized Menus
    Hide My Documents icon from the desktop
    Remove Set Program Access and Defaults from Start menu
    Remove Windows Catalog from Start Menu
    ;# Experimental #
    Remove Windows-Keys Support
    Speed-up Access to AVI Media Files
    ;# Explorer #
    Add Administrative Tools to My Computer
    Add My Network Places to My Computer
    Add Network Connections to My Computer
    Change Explorer Folder View to: details
    Disable Autorun
    Disable Prefix: Shortcut to
    Disable shortcut arrow
    Recycle Bin: make renamable
    Remove Shared Documents
    Set sound scheme to No Sounds
    Show All Files And Folders
    Show extensions of known file-types
    ;# File Open/Save Dialog #
    ;# Security & Privacy #
    Disable DCOM
    Disable Simple File Sharing
    Disable User Process Tracking
    Remove Alexa Spyware
    ;# Speed #
    Classic Control Panel
    Disable Automatically search for network folders and Printers
    Disable Info Tips on Files
    Disable Info Tips on Folders
    Disable Optimize harddisk when idle
    Disable Restore Mapped Network Drives on Logon
    Disable Tracking of Broken Shortcut Links
    Do not cache thumbnails
    ;# Visual Effects #
    [Drivers]
    [Hotfixes]
  9. #29
    Jun 2004
    NH
    Awesome
    Thats truely a sweet deal thanks chris, for everyone who doesnt know what the above post is: It's the proper nLite settings for the newer nLite using my old settings.ini
    p.s. no idea how I got the scrolly bars they just appeared, aparently the server wants you to look likje an *** with a long post hahaha.
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  10. #30
    Feb 2005
    ca
    good list, one question, you got a long list of languages, which ones did you actually kept, i checked all of mine to be removed (defaults to english), gonna test it tonight or tomorrow, its my 18 try on nlite, still cant figure out why phone control wont work, gives me the general runtime language error or something, anybody had luck with making phone control work yet? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
  1. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 03:22 PM
  2. nlite requirements for FrodoPlayer
    By knubile in forum FrodoPlayer
    Last Post: 12-02-2004, 08:22 AM
  3. Replies: 0
    Last Post: 05-18-2004, 08:38 PM
  4. Disabling safe mode in Windows ME?
    By Squeezer in forum Software & Software Development
    Last Post: 02-13-2001, 12:51 PM
  5. Win 98 safe mode
    By snakebite in forum General Hardware Discussion
    Last Post: 10-03-1999, 01:09 PM
