Page 9 of 16 FirstFirst 12345678910111213141516 LastLast
Results 81 to 90 of 156
Thread: Safe nLite setting.ini
  1. #81
    Oct 2004
    alright... so i go to nliteos.com to find the .998 version and be done with it.... but there is no link for that version... all i can find is the new 1.0
    can anyone shed some light on where to find the .998 version?
  2. #82
    May 2005
    Quote Originally Posted by ummagawd
    hmm, seems to be hard to find
    well, at least stay away from 0.999...again just my own opinion.
    Gonna try the latest when switching to newly trimmed OS, will get back on subject.
    EDIT: found a link http://www.filemirrors.com/search.sr...ins&file=nlite
  3. #83
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    Is anyone running phonecontrol?
    I have nlited, (with or without minlogon), installed directx as per phoco requirement. installed dotnetfx, as per requirement... still get an error on phoco startup... (This has been traced to nlite installs, but it doesnt have much info... here is the error anywas)
  4. #84
    Oct 2004
    *** i take that back... all of the links, while they do say .998 still links you to a 1.0 file***
    good find!! thanks!
    Quote Originally Posted by Clint
  5. #85
    Oct 2004
    does anyone have the .998 install exe they can send me?
    ummagawd@gmail.com
  6. #86
    May 2005
    ummagawd@gmail.com
    You got mail
  7. #87
    Oct 2004
    clint.... thanks for hookin it up man...!!
    ***well trying to hook it up.... i think you forget to attach the file ***
  8. #88
    Banned
    May 2005
    Clint- Send me your configuration file so I can work the size of my XP install down.
  9. #89
    May 2005
    Quote Originally Posted by E30vert
    Ehhmm..
  10. #90
    Variable Bitrate fonseca's Avatar
    Apr 2005
    Virginia
    Heh. Clint - send me your term paper so I can write the text of my paper down.
    I finally found .998, and the two configs posted here both work great, no problems yet in VPC. I'm currently tansferring the ini manually to 1.0 beta 1, less quite a few things I don't need, hopefully that will work out better than .999. I'll probably use one of the RVM update packs again, which are very convenient, and come with some nice tools.
    I'm at a 127mb ISO now, 100% stable so far, but I'm still not sure about running with no pagefile using only 256mb ram. I can max out my memory pretty easily if I try. I may have to shell out for a 512mb dimm. But that would be okay anyway if I end up not hibernating. If I can get to a 15 second cold boot I won't use hibernation. I need one of these!
    I''ve started burning my ISOs to DVD-R and overwriting previous ones. I've wasted literally a dozen CDRs on previous versions. But I'm close now to having everything like I want it.
    There'sd a lot you can remove post-install that Nlite doesn't touch. I've been doing it manually, if anyone can point me to a simple walkthrough or app for custom removal scripts, I would appreciate it.
    I've given up on integrating Minlogon into the ISO, if someone has done that successfully, please post exactly what you did.
    Intellaworks: your shell thread was veryhelpful and easy to follow, thanks.
    In progress: M10000; Travla c134; Xenarc 700TSV; Hitachi 80GB 2.5"; 256MB ULP; M2-ATX; ITPS; Powermate; iKEY SL-88 KB; Holux GM-210; Audiobahn ADD51T w/ COAX/optical converter; Road Runner; iGuidance 2.1
  1. Nlite to CF card?
    By SlashEMc2k in forum WinNT Based
    Last Post: 12-25-2004, 03:22 PM
  2. nlite requirements for FrodoPlayer
    By knubile in forum FrodoPlayer
    Last Post: 12-02-2004, 08:22 AM
  3. Replies: 0
    Last Post: 05-18-2004, 08:38 PM
  4. Disabling safe mode in Windows ME?
    By Squeezer in forum Software & Software Development
    Last Post: 02-13-2001, 12:51 PM
  5. Win 98 safe mode
    By snakebite in forum General Hardware Discussion
    Last Post: 10-03-1999, 01:09 PM
