Results 1 to 10 of 10
Thread: Nlite Xp Pro sp2 and Phone Control-help
    Constant Bitrate mick0uziel's Avatar
    Feb 2005
    ca
    ok, i have read as much as i could, nlited xp pro sp2 for about 8 times now different settings including the one i found here, still i cant make phone control to work? has anyone been able to make phone control work on an nlite xp pro? one extra question, i tried minlogon and figured what it does, but what is EWF? what does it do? thanks
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    FLAC SFiorito's Avatar
    May 2004
    EWF=Enhanced Write Filter. Filters out any writes made to a volume and keeps them in memory (or in a hidden partition). Mainly used for flash memory installations which have limited number of write cycles.
    Feb 2005
    ca
    thanks for the ewf info, so if i use my 3.5 hard drive i dont need that right!?! so that leaves me down to one last issue, does anyone have an nlite config that will make phone control work? heeellllpppp!!!
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Feb 2005
    ca
    after so many trials today, and still no success, what the heck is are the files required to make phone control work? frustrating totally, anybody answers please!!!!!
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Mar 2005
    I read somewhere that .NET framework, which Pho Co is based on, requires authentication which Minlogon cannot provide...
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    No. Your wrong minlogon logs on tot he machines default user, which would still have .net framework enabled. I'm able to use my front end which is written in .Net with my minlogon enabled system. It's definatly a nlited system problem
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    May 2004
    well, I guess the obvious questions is: does he even have .NET installed??
    Feb 2005
    ca
    yeh .net1.1 from microsoft. when installed on a non nlite OS (same computer) it works fine, but with nlite, i get errors.
    7" Lilliput
    Opus 150
    mini itx 1Ghz
    1GB sdram
    97 Prelude
    Raw Wave
    Jun 2004
    On the beach
    Which version of .NET Framework is it??? Phoco needs 1.1.4.3 or similar to that, the Windows XP version is normally 1.1 only.
    Jun 2004
    NH
    Also did you download and install the .Net redistributable from M$ ?
    does your nLite have:
    DTC, DCOM, COM+ services ?
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  1. XP Pro nlited not working with RR and Phoco
    By mick0uziel in forum WinNT Based
    Last Post: 03-13-2005, 01:18 PM
