yes, look here
Hi, I have solved my startup logon problems with twaks2000, but I don,t know how to eliminate the logon check after hibernation restore.
Any idea??
yes, look here
I had the same problem, I changed a few things at once, so I'm not sure this is the solution or not, but worth a try. Go into control panel - users and turn off fast switching.
minilogon helps too
Had the same problem,
Control Panal > Power Options > Advanced > Uncheck "prompt for password";
If I remember right, that's what I did.
Edit: Just tried it, and it works.
