Page 5 of 5 FirstFirst 12345
Results 41 to 45 of 45
Thread: How to: Change windows shell
  1. #41
    Maximum Bitrate locs4dayz's Avatar
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by Noldona View Post
    I would suggest setting up the shell being booted based upon the user. I have this set up on my home machine. For the carpc I would suggest making your admin account have the standard explorer.exe and your commonly used account have the replacement shell.
    I don't remember what the keys are off hand. When I get home from work I can look at my registry and find out what they are and what values you should have in there.
    How can I be sure I choose the correct "User" GUI to edit? Do I look for the user name???
    Just for kicks I navigated to "HKEY_LOCAL_MACHINE\Software\Microsoft\". There is no entry "current version" listed there. Navigated to "HKEY_USERS\Software\Microsoft\". There is no entry "current version" listed there either. Went to "HKEY_CURRENT_USER\Software\Microsoft\", and its not there either. WTF???
    UPDATE: Forgot to enter "\Windows NT". Do I do the edit in "HKEY_CURRENT_USER" or "HKEY_USERS"??? I want to get this right the first time!
    Thanks in advance!!!
    Linux(Learning the curve...Like when driving!!!)
    Worklog!!!http://www.mp3car.com/vbulletin/fabr...l-worklog.html
  2. #42
    Sep 2009
    Philadelphia, PA
    Bump...
  3. #43
    Sep 2009
    Philadelphia, PA
    Quote Originally Posted by IntellaWorks View Post
    GPEDIT.MSC hack
    Ahh so you don't have ewf but still need a way to change your shell ? here ya go:
    Start->Run->GPEDIT.MSC->user config->admin templates->system-> right hand pane look for (custom user interface) and change this over to point to your front end.
    Will this approach set the current desktop permanently. Seem a lot easier than messing with the registry
  4. #44
    jtm
    jtm is offline
    Newbie jtm's Avatar
    Apr 2008
    Ohio, US
    I have written this small app and thought it would be useful, it will force windows explorer to open as a shell (showing the taskbar and start menu) instead of just a window after the default shell has been changed through the registry settings to your frontend, This way my front end starts as the shell but when I need to do maintenance I can still access the full windows shell without hassle or closing my frontend.
    ShellStarter.zip
    Enjoy
  5. #45
    Apr 2012
    Is it possible to load a VNC client session like this? Say, to have the VNC session embedded as if it were a desktop wallpaper? Maybe also retain the Windows taskbar, and possible windows on top of the VNC session in the desktop?
  1. Windows Automotive(R) and Kenwood
    By vision in forum Software & Software Development
    Last Post: 06-14-2006, 07:16 AM
  2. Replies: 11
    Last Post: 10-08-2004, 07:59 PM
  3. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 12:40 AM
  4. change color of windows startup background?
    By aoLhaTer in forum Software & Software Development
    Last Post: 06-17-2004, 10:16 AM
  5. Windows ME and MediaCar
    By dug1967 in forum MediaCar
    Last Post: 04-15-2004, 01:30 PM
