Results 1 to 9 of 9
Thread: EWF with XP
    Apr 2005
    EWF with XP
    I whant to use ewf with xp pro. I dont whant to use ram cache, I whant disk cache. How can i do it?
    Maximum Bitrate LagunaICE's Avatar
    Mar 2005
    Czech republic
    not with EWF.
    Apr 2005
    Why? EWF supports disk overlay mode. But how can i enable it on normal xp?
    Mar 2005
    Czech republic
    Yes, you can use EWF with WinXP (even Pro). Search the forums:
    http://www.mp3car.com/vbulletin/sear...earchid=823878
    However, since you whant a disk cache, not a mem cache nor a black-hole wash machine you are outta luck.
    FLAC SFiorito's Avatar
    May 2004
    LagunaICE:
    ssmaxss: hey man, i've been meaning to look into configuring disk overlay mode but it's a bit more complicated because that's typically set up by First Boot Agent in XPe. It needs to create a hidden partition on your drive and all that stuff. I recommend you look into the EWF API DLL. There's a "ConfigureEWF" function or something similar that I think does all the setup. It'll probably take a lot of tinkering in Virtual PC.
    Apr 2005
    What ewf api dll do you mean? ewfapi.dll or ewf apifrom ewf sdk?
    May 2004
    the API dll that comes with the XPe tools. There's no EWF SDK that I know of.
    Here's the function you want to use: http://www.msdn.microsoft.com/librar...nfigureEwf.asp
    The best way to go about this is use the XPe tools to create an image with disk overlay, then load it into Virtual PC to see what the FBA registry values are so you can copy them over to your XP Pro system, then run ConfigureEwf. Looks pretty simple once you get the registry values.
    Apr 2005
    I know ho to do it! Have anyone got EWF API SDK and ewf files from xpe sp2? (I have only sp1). Please send them me. I need all ewf*.dll ewf.sys ewfmgr.exe + ewf SDK.
    Apr 2005
    Hm... I have copied registry values, runned ConfigureEwf and nothing happens...
  1. Using EWF on regular WinXP
    By SFiorito in forum WinNT Based
    Last Post: 03-17-2009, 07:43 PM
  2. Windows XP w/wireless Linksys USB vs NetStumbler trying to wardrive
    By clean customs in forum Wireless Communications
    Last Post: 01-07-2009, 12:18 PM
  3. Software Review: Windows XP Media Center 2005 Edition!
    By nFiniteTuning in forum The Review Palace
    Last Post: 05-01-2007, 12:54 PM
  4. Another crazy mod: RAM booting XP (no, not EWF)
    Last Post: 01-18-2007, 08:39 PM
  5. Difference between Windows XP Home & XP Pro?
    By grandamp3 in forum Off Topic
    Last Post: 02-21-2003, 06:07 PM
