nLite is an all-in-one GUI utility that will give you the ability to permanently remove unwanted components such as Internet Explorer, Outlook Express, Media Player, MSN Explorer, MSN Messenger and a variety of other components from your own Windows CD. This results in a slimmer Windows CD, faster Windows installation, more hard disk space, and is also known to free up RAM resources when using a cut-down version of Windows.
Once it has finish the removal of components of your choice, you are given the option to create a bootable ISO of Windows XP which you can test in a Virtual environment or burn straight to CD media. nLite also includes an automated slipstreamer for slipstreaming a Service Pack on the go. And best of all, its free!
Link:-
http://www.msfn.org/comments.php?shownews=12746
Details
#0.99.9b
General
new: Services Configuration subpage in Options
new: Keep code pages of removed languages option
new: Auto Pre-Slipstream cleanup if needed
update: Textmode driver selection prompt
update: Merge to Recompress, original structure of CABs with same reduction
update: Duplicate files removal suspended, now smaller final install
update: Keep/Remove boxes moved to Components - Advanced menu option
fix: Manual install bogus missing files report
fix: Textmode driver integration
* Windows 2000 DELL PERC RAID
* Nvidia RAID
fix: Manual path when CD selected loop warning
fix: SIF line 139 error
fix: RVM Hotfix pack SFC issues and 1.2.1 support
fix: Object Reference not found during processing
fix: Tweaks
fix: Population of DllCache if SFC left enabled
fix: Windows 2003 SP1 setup restarts
fix: Office updates not installing on enlighten OS
Components
new: Map Network Drives/Network Places Wizard
new: Color Schemes
update: Midi support MIDIMAP left
update: Separated Hardware Support components
update: Languages separated in groups
update: OOBE doesn't need SENS, SENS more friendly
fix: Languages listed twice
fix: Help (missing files on Printer install)
