sorry, txtsetup.sif, i wasn't there with the files when i made the post, so there ya go, thats where im recieving errors, pretty much with all of the driver removal areas
when a line errors it has a ; before the line, i remove that, no more error, ill test to see it this works out,
all i can see is sweet, its installing now in vmware, so , maybe that can be a quick fix, since all drivers, that get removed, will result in this errors, except monitor drivers so far, i belive
LinkBack URL
About LinkBacks
before the install of
I cheat... use the "expand" command to decompress the files and you can either just rename them to *.in_, *.ex_, etc. or use the "compress" command (I think). if you just rename them then "expand" will see it as having 0% compression...
yeah, i'm lazy..
