Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: Possible solution for saving files on EWF systems (without disabling EWF)
  1. #11
    FLAC SFiorito's Avatar
    May 2004
    that's more dependent on the front end. I think most front ends should be "power-aware" so if you go to sleep or hibernate they continue playing once you resume. in order for a front end to be HORM/EWF-aware it would need to save its state in a file on a writable partition and read that data upon resuming since each time it resumes will be from the original HORM state. I don't know which, if any, front ends do that.
    EWF, HORM, MinLogon on XP.
    Zotac ION Atom N330, 2GB low-profile RAM, M3-ATX
    Win Embedded Std 2011 RC
    OCZ Vertex Turbo 30GB SSD
    Lilliput 629 Transflective, WRX Screen Mount
    BlueSoleil BT, i-Blue GM-2 GPS, DirectedHD Radio, Andrea Mic
    VoomPC 2
  2. #12
    Vendor - Qube colin's Avatar
    Dec 2006
    Good idea SFiorito, I've got a few questions though:
    Firstly, where are the SDI files located? I looked through the "XPeSP2FeaturePack2007" iso that I found all the EWF files in, but without any luck.
    Secondly, isn't it supposed to be possible to only protect a single partition? I don't have any need for EWF at all besides to maintain my HORM file. I created a partition (C that has all my static data on it (drivers, frontend, etc) and another partition (D on the same hard drive that should later have settings and music. However, even if EWF is disabled on D, once I resume, all the data is erased and it goes right back to how it was when I hibernated. That's why I'm looking into this, but before I go installing the SDI stuff (assuming I can find it :P) is there any way that I could just unprotect the D drive?
    Thanks a lot ahead of time : )
    EDIT: Found the SDI files -- for anyone wondering; you have to download the SDI tools installer. When it asks what to download, only get the Tools part (which is like 7 megs). Then extract the files in disk1 and the SDI.* files should be there. To get sdiaut.dll, you need to acutally run the installer, wait for it to create all the files, then copy it out of the /bin directory. I did this while the installer was running and then clicked Cancel so that it automatically erased all the rest of the files. I grabbed sdiloader.exe from the /bin directory too since it's needed to create/manage the SDI disks. It offers to install the drivers for you upon starting, so that may save a few steps. Still want to know if you can just leave a partition unprotected.
  3. #13
    Variable Bitrate csfile's Avatar
    Feb 2009
    Quote Originally Posted by colin View Post
    also looking for an answer to this...I'm looking to do something similar
    EDIT: gonna see if i can figure this out: http://msdn.microsoft.com/en-us/library/dd143253.aspx
    also gotta try this out: http://www.mp3car.com/vbulletin/winn...ager-tool.html
  1. Using EWF on regular WinXP
    By SFiorito in forum WinNT Based
    Last Post: 03-17-2009, 06:43 PM
  2. MINLOGON without ewf, easy install with files
    By syfenx in forum WinNT Based
    Last Post: 06-07-2005, 10:48 AM
