Results 1 to 5 of 5
Thread: Remote Registry Help.
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I'm retarded first off, I worked on my car pc all day making careful adjustments to the system and hardware. Finally on the last step which was pointing the shell to my custom front end I blew it.
    my front end is located @ D:\FrontEnd\CarInterface.exe I put: d:\frontend\CarInterface.exe (notice the Lower case letters) of course now I've got a blank screen and no CTRL + ALT + DELETE (because I'm using minlogon)
    Because I made a direct change to the registry and using nLite I'm not sure that F8 (safe mode) will work but I'll try that today.
    I was thinking of trying to load a Pre Installed Envirnment, like Bart PE and try to access the registry that way.
    I can remove the systems drive easily and access all the data on my development machine, is there a way to view the registry so I can make the correction through my development machine ?
    Anybody have any other suggestions, ohh one other thing I have a backup of the registry on the system, there must be a way to recover it using just DOS.... I feel foolish for not knowing just how to though.
    I appreciate any input guys, I'm hopeing to post results so that if others find themselfs in my perdiciment they can recover from thier issues fast.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    See me in my wet t-shirt. stevieg's Avatar
    Aug 2003
    Warwickshire, UK
    Quote Originally Posted by IntellaWorks
    If you have a reg backup, you can insert a bootable windows XP cd and select to open the recovery console, which is similar to a DOS prompt.
    What is the file name of your reg backup?
    If you can put it on a LAN see if you can ping it when it enters windows. If so, you can map a drive to C$ to set admin password, then open regedit on the remote machine and connect to the remote computer.
    Ford Focus MP3 : www.stevieg.org/carpc Blog Updated 29 January 2009!
    Car PC Status: Complete - Undergoing Software Redevelopment
    Raw Wave
    Jun 2004
    On the beach
    BartPE should allow you to do it easily.
    FLAC SFiorito's Avatar
    May 2004
    you can load the hives in regedit. in this case you'd want the software hive. they're stored in system32\config
    Jun 2004
    NH
    Thanks guys I had a bit of a brain cramp on this situation, ever since I got a puppy my work has degraded !!!
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
  1. Relocating Portable DVD Remote Sensor...
    By AEFL92 in forum General Hardware Discussion
    Last Post: 09-10-2007, 04:03 PM
  2. Automotive Security
    By Maeveth in forum General MP3Car Discussion
    Last Post: 04-07-2004, 02:33 AM
  3. ME 2.0 Official Bug Reports
    By phat_bastard in forum ME Archive
    Last Post: 01-31-2004, 07:27 PM
  4. One remote to control them all
    By liquid_smoke in forum Input Devices
    Last Post: 01-22-2004, 10:00 AM
  5. ps2 pelican remote w/ creative reciever & girder
    By ShinkunoNamida in forum Input Devices
    Last Post: 04-26-2003, 03:00 PM
