You can you the minilogon from Embedded XP!
Check this thread out!!
New EWF + MinLogon and CF instructions
When XP first boots up, I am allways faced with the logon screen before windows starts up. How do I avoid this.
I am using XP PRO SP2
You can still have something if you have nothing
Its down!!!! Sold the Golf so took it out, it's still alive but not installed.
Progress [-----------] 0%
Who the Daddy Iz!
<---for once I got to use this on someone eles
here
If you don't like minlogon you can use this simple regedit:Originally Posted by HummDinger
[CODE] start
Windows Registry Editor Version 5.00
[HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\Winlogon]
"DefaultUserName"="yourname"
"DefaultPassword"="yourpassword"
"AutoAdminLogon"="1"
[CODE] end
..plug ur name and pass.(must match ur current one), save as whatevvaname.reg and doubleclick it...
if u wanna disable the autologin just make a new file for doubleclick with the value "AutoAdminLogon"="0"
that will give u just a nice xp background and ur in..![]()
and if i return from hibernation? windows xp ask me the password of my account, and i cant press ok in touchscreen because it will active next from ask me the passwork, any suggest?
Renault Megane Coupé Cabriolet
P3 550 mhz 256 mb RAM 15 gb hd, dvd.
gps handsfree parrot ck3300
windows xp sp2
road runner
map monkey and viamichelin mapsonic
Touchscreen 7" fully motorized in-dash
I bet you have the .NET framework installed. The cleanest way is to delete a HIDDEN user account: ASP.NET for your Accounts. If you have more than one account windows show up the winlogon screen to select the user. Now siince it is hidden you cannot see it. Delete it and you will boot directly into windows all the time!
Time displayed in a different way!
http://www.lares.dti.ne.jp/%7Eyugo/s.../03/index.html
http://www.humanclock.com/
FREE 3D Glasses: http://www.rainbowsymphony.com/freestuff.html
Try this:Originally Posted by xuri
Config panel - Display settings.
Screensaver tab.
Power.
Advanced tab.
deselect: Prompt for password when computer resumes from standby (/ hibernation)
i only have the administrator user and on advanced tab, i have deselected this option .. it's ok!!!
windows xp sp2
road runner
