Results 1 to 10 of 17
Thread: Alternative to Hibernation..
    Jun 2005
    I'm planning to use Windows XP in my project, but the problem is that the motherboard does not support Hibernation.
    I remember that somebody mentioned 3rd party program for XP that did same as hibernation.. saves memory to disk and allows quicker boot..
    But i cannot what that program was.. or is it even possible if motherboard does not support hibern.?
    If somebody knows any of these programs, give me a shout..
    My boot time is now about 1min, after nLited installation. next step would be hibernation and EWF, but that damn motherboard is now giving me a hard time.
    And changing the mb is not an solution...
    Raw Wave god_of_cpu's Avatar
    Jan 2004
    SilverSpring Maryland
    Quote Originally Posted by Jehvi
    You should change the mb.
    StreetDeck.com Developer (I am Chuck)
    Get StreetDeck at http://www.streetdeck.com
    The Official StreetDeck Forums have moved, please visit us at http://www.streetdeck.com/forum for official support for Streetdeck.
    Raw Wave
    Jun 2004
    On the beach
    Pretty much every motherboard supports hibernation, if not all.
    Check your display drivers to make sure they are the correct drivers.
    Oct 2004
    Canada
    I know that i used a copy of windows and this didnt alow me to hibernate
    Then i put on a different copy and it worked fine.
    Jun 2005
    make sure hibernation is enabled in windows. go to control panel -> power options and make sure that it's enabled there.
    i believe it's off by default.
    Jun 2005
    Quote Originally Posted by JiveMofo
    The problem is that i dont even have that tab in Power options.
    Does anybody know what things i should left alone when using nLite, so i dont broke hibernation?
    Raw Wave
    Jun 2004
    On the beach
    Did you untick the turn hibernation off?? If not you will have disabled hibernation on your install.
    Jun 2005
    Where in latest nLite i can find that "turn hibernation off" setting?
    Raw Wave
    Jun 2004
    On the beach
    Its under the unattended settings on the second tab (General 1/2)
    Jun 2005
    I checked.. and it should be on (not ticked)... i currently installing full XP setup. Just to see if it allows me to hibernate.. If it does, then the problem is in nLited installation..
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 03:16 AM
  3. I'v had a thought! - Make Hibernation Better?
    By mick-uk in forum WinNT Based
    Last Post: 05-19-2005, 09:39 AM
  4. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
  5. Not coming out of Hibernation (Intermittently)
    By Jailer in forum General MP3Car Discussion
    Last Post: 10-23-2004, 10:11 PM
