Results 1 to 7 of 7
Thread: horm without ewf
    z.1
    z.1 is offline
    Aug 2003
    horm without ewf, is it possible?
    i've been reading through the forums a lot , since i am about to install another carpc in my new car. i do basicly like the idea of starting the system with HORM , but i don't want to use ewf , because of the writeprotection.
    is there any other way , to use the same hibernation image evereytime, and leave the drive writeenabled ?
    thnx
    Constant Bitrate dan__wright's Avatar
    Apr 2005
    UK
    you could copy over the files that are needed for ewf, make reg chnages but just disable to protection.
    should work, has anyone tried it? im also looking at going down this route.
    Audio: Alpine PXA-H700 DSP, Rockford Fosgate Punch P4004 amp, P152S Comps and Alpine SWR-1242D Sub
    PC: BU-303, SB Audigy 2 ZS, Jetway 1.5Ghz, Cubid case, M2-ATX PSU, New 700tsv
    Toys:K8055 relay board, Elmscan OBDII
    Type-R Mini
    FLAC SFiorito's Avatar
    May 2004
    ewf needs to be installed and running in order for HORM to work
    z.1
    z.1 is offline
    Aug 2003
    Quote Originally Posted by SFiorito
    is there no other software to achieve the same goal?
    btw. does ewf necesserily reguire to writeprotect the drive ?
    May 2004
    EWF redirects writes from the physical disk to either RAM or a hidden partition. If you want to prevent writes to your disk then that's what you need to use. There was some other tool (ReadyOn, I think) that claimed to optimize the hibernation process, but I haven't heard anything about it in a long time.
    Variable Bitrate BMVEE's Avatar
    Mar 2005
    Beautiful British Columbia, CANADA.... eh!
    http://www.directinsight.co.uk/produ...m/readyon.html
    May 2004
    after checking out Venturcom's website it seems like this works the same way as EWF/HORM. So it needs to be running (protecting the volume from writes) in order for the HORM functionality to be working.
  1. Using EWF on regular WinXP
    By SFiorito in forum WinNT Based
    Last Post: 03-17-2009, 06:43 PM
  2. Replies: 12
    Last Post: 03-16-2009, 07:00 PM
  3. MINLOGON without ewf, easy install with files
    By syfenx in forum WinNT Based
    Last Post: 06-07-2005, 10:48 AM
  4. HORM and RoadRunner...
    By CornFlake340 in forum Road Runner
    Last Post: 04-14-2005, 04:17 PM
  5. using EWF + HORM
    By BOND007BE in forum WinNT Based
    Last Post: 03-29-2005, 02:41 AM
