Results 1 to 4 of 4
Thread: EWF ntldr
    Apr 2005
    EWF ntldr
    Okai im trying to get EWF going so i can get HORM going, but in the instructions from here it says to
    "Place ewfntldr on the root of your boot drive. Rename ntldr to ntldr_bak and rename ewfntldr to ntldr"
    What is this ntldr file? there is no ntldr file in the ewf zip, only the ewfntldr. But according to the instructions this ntldr file should already be in my root directory. But i cant find it and i dont know what it is.
    Low Bitrate Zharvek's Avatar
    Jan 2005
    In your root drive, C:\ should be a hidden file called ntldr rename that to ntldr_bak and then unzip the ewfntldr into C:\ and rename that to ntldr.
    Variable Bitrate anky1's Avatar
    Apr 2005
    to see ntldr you need to turn on view hidden files...
    open my computer>>tools>>folder options
    'view' tab
    radio button 'show hidden files and folders' then see if you see it again
    RIP 1993 civic sedan
    RIP 1993 civic Del Sol
    Hello! VW Golf 1.8t
    Apr 2005
    dont worry, there was another option that hides protected operating system files. Thanks anyways.
  1. Using EWF on regular WinXP
    By SFiorito in forum WinNT Based
    Last Post: 03-17-2009, 06:43 PM
  2. Replies: 12
    Last Post: 03-16-2009, 07:00 PM
  3. MINLOGON without ewf, easy install with files
    By syfenx in forum WinNT Based
    Last Post: 06-07-2005, 10:48 AM
  4. EWF in place of Deep Freeze for Home PC?
    By migel628 in forum WinNT Based
    Last Post: 02-21-2005, 11:53 PM
  5. cant turn off ewf!
    By mick-uk in forum WinNT Based
    Last Post: 01-01-2005, 05:01 PM
