Results 1 to 10 of 13
Thread: Won't boot when USB HD plugged in?!
    Jul 2004
    I'm slowly preparing my machine for a CF install.
    When I attempt to boot my computer with the media drive (external USB 40GB HD) it freezes at the VIA logo screen. If I unplug the USB HD (even without rebooting) the boot process continues. I've looked in the BIOS for a setting that would be making it do this but I can't figure it out?!
    Is the computer attempting to boot off of the USB HD, which only has media files on it?
    What BIOS setting is causing this to happen?! HELP!
    Jul 2005
    Boot order
    Try checking the boot order in the BIOS, put your C: drive first, then CD-ROM, etc. Just remember when you go to format it that you have to switch the boot order again. If that doesn't work, some BIOS have a USB setting in them to boot up with the computer, turn it off, it should activate when windows calls for it. I'm not sure though.
    Elsewhere
    Also check to make sure USB boot is disabled. At the very least having USB boot enabled will add substantial time to your boot.
    Edit: I'm not awake yet, and can now see that Thanatos said the same thing. <pours more coffee>
    How about the Wiki?
    Mo' Programming Mo' Problems
    Sonicxtacy02's Avatar
    Woodbridge, VA
    Blog Entries
    55
    it doesnt freeze... its just doin some type of drive check. Happens to my 120gig usb too. If you wait it goes away. I cant remember what the drive test is.. i think it starts with a d (DMA maybe? )
    FLAC IntellaWorks's Avatar
    Jun 2004
    NH
    I ran into this problem with a USB CDROM drive, with my via board. The USB drive wasn't working correctly with via's BOIS. The device worked with other machines but not my via board.
    If you have another harddrive try that. Obviously try the first suggestions posted as these should fix most common problems.
    Edit: The Cd-ROM drive actually died shortly after this weird problem so maybe it was on its way out to begin with. However my via board had the same behavior as your board... It was just a hard problem to trouble shoot.
    Progress [I will seriously never be done!]
    Via EPIA MII
    512MB RAM
    OEM GPS (embedded)
    nLite WinXP pro on
    1GB Extreme III CF card
    Carnetix 1260 startup/ DC-DC regulator
    Software: Still, re-Writing my existing front end in .Net
    Maximum Bitrate knubile's Avatar
    I had this same experience. Try turning off the via logo so you can see exactly what's happening. Mine was freezing during the ram test. I found no way to fix it, but when I tried a different USB enclosure for my laptop drive the problem went away. I found 2 enclosures that caused the problem, and now I have one that doesn't.
    These USB enclosures are surprisingly dissapointing.
    I have yet to find a really good one.
    Good luck.
    Jul 2004
    Thanks for all the suggestions. So far Knubile's explanation seems best - I tried putting the laptop HD into a different USB enclosure and was able to get the computer to boot...
    BUT - once in windows, the USB is not recognised!!! WTF...any ideas? Would yet another USB enclosure act differently?
    Jul 2004
    I just tried booting my computer with my ARCHOS G-Mini XS200 (MP3 player) plugged in and it didn't freeze, and windows recognised it once booted. Weird...
    I'm going to be using this Archos player as my media drive since in the winter I can take it out with me and use it as a regular MP3 player, but once plugged in, it keeps a directory structure of my music and acts as a regular USB hard drive so it works perfectly for Frodoplayer.
    Low Bitrate jadz's Avatar
    I am having this same problem with a Nexstar 3 enclosure.
    Just as described, if the USB-HDD is plugged in it won't complete the memory, as soon as I unplug the drive it continues the boot process, so if I unplug the drive for a total of .5 seconds and then plug it back in everything works fine.
    Very odd.
    Nov 2004
    NYC
    Quote Originally Posted by jadz
    Very odd.
    I've experienced this on computers at home and at work. Seems like some BIOSes get stuck on external storage media. I've had this occur with USB drives as well as media card readers. Unplug them for a few seconds during POST and everything is fine. *shrugs*
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. Speed up USB HD transfers in Windows.
    By Custommx3 in forum WinNT Based
    Last Post: 04-01-2005, 04:48 PM
  3. FS: 2-40gig 2.5" laptop HD in external USB 2.0 enclosure
    By riddle14 in forum Classified Archive
    Last Post: 03-19-2005, 11:41 AM
  4. Hauppage USB TV/FM line-in noise/whine- Grounding
    By live2themaxuk in forum General Hardware Discussion
    Last Post: 11-16-2004, 09:20 AM
  5. Can I boot from a removable USB Hard Drive?
    By ayclens in forum General Hardware Discussion
    Last Post: 11-12-2004, 03:43 PM
