Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
Thread: Using Windows Server 2003 for CarPC
  1. #11
    Elsewhere
    Quote Originally Posted by xxxomxxx
    hi all
    if i use Media Portal as shell, i just dont know how to get the other prgrams running....
    im using the following as a frontend:
    C:\Program Files\Team MediaPortal\MediaPortal\MediaPortal.exe
    But i need following Startup entries to start
    C:\Program Files\SOUNDGRAPH\iMON\iMON.exe /startup (<-dont know if i need the startup command)
    C:\Program Files\Motherboard Monitor 5\MBM5.exe
    C:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
    help would be greatly apreciated...
    First, this has nothing to do with this thread.
    Second, this has been brought up already. Go check out the FAQ Emporium. I believe the answer you seek is there.
    How about the Wiki?
  2. #12
    Jan 2004
    NYC
    Quote Originally Posted by LittleDragon
    I use 2003, it's fast on bootup. The main reason is I don't want to use a keyboard and if XP chokes in restoring the hibernation file, you get prompted to continue booting or delete the hibernation file. 2003 doesn't do that, if it chokes, it'll just try restoring the file be default, no need for a keyboard.
    interesting, but wouldnt you still have to hit f8 to bring up the prompt thats gives you the option to continue booting or delete the hib. file
  3. #13
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    ou do have a point but it is a little overkill as you have the reset button if all else fails.
    Terran
  4. #14
    May 2005
    Quote Originally Posted by ccsnet
    Terran
    What he is talking about is the situation when the XP recover from hibernation mode fails. After this, XP will not boot until you plug in a keyboard and choose either "delete hibernation file and boot normally" or "try again". Win2k3 deletes this file by default and boots normally if hibernation fails(i think).
    I really hate this in XP, becuase it is the only thing I ever need a keyboard for during "normal" operation of my CarPC.
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 04-12-2012, 08:29 PM
  2. File/web/print Server
    By Quattro in forum Off Topic
    Last Post: 04-15-2005, 10:26 PM
  3. Programming for Pocket PC (Windows Mobile 2003 Second Edition)
    By DjBac in forum Software & Software Development
    Last Post: 01-04-2005, 03:36 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
