Results 1 to 10 of 14
Thread: Using Windows Server 2003 for CarPC
    Low Bitrate bLindmOnkey's Avatar
    Jan 2004
    sdale
    Was wondering if anyone's ever thought of this or acually done it. Afterall, it runs great on slower systems, is more stable than xp due to a newer kernal, and there are complete guides to make Server2003 run just like an XP workstation such as this one:
    http://www.msfn.org/win2k3/
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    it loads more stuff during bootup though... therefore you have longer boot times.. which is something we are trying to eliminate...
    however.. if you do use hibernate/standby it can be a viable option... although in my experience.. its not XP that causes a pc to crash.. its more often than not the software you run on it...
    Constant Bitrate techeros's Avatar
    Mississippi
    Interesting... but my first reaction was WHY?
    We run 14 2k3 servers here all are pretty stable untill either a patch for M$ is applied or we do something to hork it up. I know a ton of services can load on 2k3, and it looks like it can be scaled down it that article.
    Is xp home/pro THAT unstable to have to install server 2k3?
    03' Toyota Tundra T3 Special Edition - Polk Audio speakers - Sony 4ch amp - RF Sub amp
    Carputer Planning |---------*|
    Overall Implementation |---------*-|
    (Stereo complete)
    Computer installed and working
    Oct 2003
    Vancouver, BC
    I use 2003, it's fast on bootup. The main reason is I don't want to use a keyboard and if XP chokes in restoring the hibernation file, you get prompted to continue booting or delete the hibernation file. 2003 doesn't do that, if it chokes, it'll just try restoring the file be default, no need for a keyboard.
    Oct 2004
    South Carolina
    Windows 2003 is a very sleek and sexy operating system! I used to run it as a desktop OS after following a guide like the one mentioned to make it more like a workstation OS.
    I'd still be running it today, if it weren't for games like Doom3 that *REQUIRE* windows XP, and won't run otherwise (unless you get a patch..)
    I wonder if we could get a project like nlite started for Win2k3 ... but probably not likely, since Windows Vista is right around the corner..
    Dec 2004
    nlite already works for win2k3
    May 2005
    Quote Originally Posted by mattress
    Actually you can grab Application Toolkit @ MS for free and then emulate XP when installing....it's a matter of minutes and you will be able to install pretty much anything on a 2003 box
    The stayaway's are AV's ofcourse...but apart from that...no prob.
    Jan 2004
    sdale
    if by around the corner you mean a year or two, then yeah maybe vista is around the corner, but vista still runs like crap on today's systems (which by the time vista comes out will be)
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I have a dual boot on the car system
    Win 2003 Server
    Win XP Pro w/ Mac U/I ( default 3 sec delay )
    Jan 2005
    other Apps needed
    hi all
    if i use Media Portal as shell, i just dont know how to get the other prgrams running....
    im using the following as a frontend:
    C:\Program Files\Team MediaPortal\MediaPortal\MediaPortal.exe
    But i need following Startup entries to start
    C:\Program Files\SOUNDGRAPH\iMON\iMON.exe /startup (<-dont know if i need the startup command)
    C:\Program Files\Motherboard Monitor 5\MBM5.exe
    C:\Program Files\SlySoft\AnyDVD\AnyDVD.exe
    help would be greatly apreciated...
  1. How to: Change windows shell
    By IntellaWorks in forum WinNT Based
    Last Post: 02-11-2011, 02:14 PM
  2. File/web/print Server
    By Quattro in forum Off Topic
    Last Post: 04-15-2005, 10:26 PM
  3. Programming for Pocket PC (Windows Mobile 2003 Second Edition)
    By DjBac in forum Software & Software Development
    Last Post: 01-04-2005, 03:36 PM
  4. Windows Freeze When Crank, Crank again windows unfreeze
    By antimatter in forum Power Supplies
    Last Post: 07-27-2004, 01:40 AM
  5. A few observations in OS and why I'm now using Windows 2003...
    By Mastiff in forum Software & Software Development
    Last Post: 01-21-2004, 10:11 AM
